cast iron vs stainless steel manifold
Re: cast iron vs stainless steel manifold (aznxmike)
Assuming 2 identical manifolds, there won't be any performance difference, and likely you wont have the car long enough to see a difference in reliabilty between a cast iron and cast stainless manifold, but the stainless will sure look alot nicer after a few months. Then again you could just get a cast manifold for less money and have it ceramic coated, which will prevent rust and may spool the turbo faster.
Personally, for me it's more about function than the way it looks. A ductile cast iron turbo manifold will without a doubt out last anything else out there. That is the reason that every oem turbo car has a ductile cast iron manifold.
Tubular designs are getting better, and manifolds like Lovefab and some of the others make great power improvements over cast manifolds and seem to last a relatively long time as well, but i'm still a little leary about a stainless turbo manifold. I'll wait a few years to see how badly they will crack....if they don't...maybe I'll buy one too...
Re: (Boondock Saint)
Seems like I have seen plenty of cracked drag and greddy cast manifolds.Aside from the ssac stuff the majority of the tubular ones are pretty reliable.
Glenn
Glenn
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boondock Saint »</TD></TR><TR><TD CLASS="quote">Personally, for me it's more about function than the way it looks. A ductile cast iron turbo manifold will without a doubt out last anything else out there. That is the reason that every oem turbo car has a ductile cast iron manifold.</TD></TR></TABLE>
I thought the reason (or maybe another reason) that all OEM manifolds are cast iron is because they are easier and faster to mass produce, hence less expensive to make. Aren't cast iron manifold made by pouring the iron into a mold. And from the looks of it almost all tubular manis are either hand assembled or maybe use a litte robotic assistance to assemble.
Re: (egvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egvtec »</TD></TR><TR><TD CLASS="quote">stainless steel is because it doesnt rust</TD></TR></TABLE>
Stainless steel is rust-resistant, not rust-proof. It can still corrode away from elements interacting with it. It's still made out of iron, add some oxygen and you have iron oxide ~ rust.
Modified by backpurge at 3:59 PM 2/4/2005
Re: (MMsportsRexSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MMsportsRexSi »</TD></TR><TR><TD CLASS="quote">cracked cast manifold = cant weld/fix
stainless = fixable!</TD></TR></TABLE>
Stainless steel and cast manifolds = Weldable
Re: (MMsportsRexSi)
any manifold that cracks = crap!
hehehe, j/k...just wondering though, what types or brands of cast manifolds are more prone to cracking?
Thanks
Thanks
Re: (MMsportsRexSi)
Not true, cast manifolds can be welded and hold very well if it's done right. I had my 1G Talon stock manifold welded (it had a nasty crack from running lean and hot..previous owner), the weld never broke after 2 years of beating the hell out of the car.
i just got a blox manifold.....are they cast iron or cast steel? ....if so it looks like it may be coated...anyone know if they are coated or if they will rust over time? if so i need to get it ceramic coated.
Re: (aznxmike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznxmike »</TD></TR><TR><TD CLASS="quote">thanks for all the info, one last question, if i do get a cast iron manifold how do i go about getting it ceramic coated?</TD></TR></TABLE>
Send it to a place like this:
http://www.qccoatings.com/contact_us.htm
Expect to pay around $50, or so to have the manifold ceramic coated.
Boricuanology
07-25-2006 11:04 AM
Midwestrider
02-05-2003 03:40 PM
