How to "clock" my turbo
i need to adjust the turbo so that the oil lines are facing correctly and the turbo faces the right way as well. what is the best way to do this? is there a DIY anywhere?
Re: How to "clock" my turbo (abmerop18)
yes.....go out to your garage and DIY ....
just loosen the bolts on the compressor and turbine and rotate it which ever way you need to, than tighten it back up
Re: How to "clock" my turbo (DC2R714)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2R714 »</TD></TR><TR><TD CLASS="quote">http://www.evans-tuning.com/vi...clock</TD></TR></TABLE>
thanks man
thanks man
i just did the exhaust housing on the wrx turbo i picked up. just removed the vband clamp and then took a small rod of brass(softer than the housing) and a hammer and while holding the compressor side, had my dad it on the housing side to side till it came off.
it took ALOT to get it off since the housing slids ontop of part of the center section.
RACEPAK
01-22-2008 05:50 PM
Exvtec king
17
07-10-2007 11:07 AM
