fuel pump and ignition question
Old Feb 4, 2005 | 10:19 AM
W.Zero's Avatar
Default fuel pump and ignition question
i am now redoing my turbo setup and had a question on the fuel pump and ignition. i have a bbk 255 intank pump and a msd 6al ignition with ss blaster with blitz 8.5mm wires. i just bought a t3/t67 turbo and will be boosting 11-13lbs for the street and IF i ever get to the track, at 21-22lbs. before i just put this turbo on and re dyno from my t3/t04e should i upgrade my pump and ignition? did a search and all the big number guys i seen are using areomotive pumps, which i dont mind getting but if not needed then i can wait. same with the ignition.
at 13 lbs i hope to hit somewhere of 420-430 and 22lbs OMY i dont know.
Old Feb 4, 2005 | 10:31 AM
tgreaves's Avatar
Default Re: fuel pump and ignition question (W.Zero)
Why does it matter what psi you hit your hp at.. Figure out what hp you want and do whatever it takes to get there..
Old Feb 4, 2005 | 10:36 AM
W.Zero's Avatar
Default Re: fuel pump and ignition question (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">Why does it matter what psi you hit your hp at.. Figure out what hp you want and do whatever it takes to get there..</TD></TR></TABLE>well thats why im asking. i guess my question should of been is my fuel pump and ignition good enough for 500+? my goal is to hit 550.
Old Feb 4, 2005 | 11:13 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W.Zero &raquo;</TD></TR><TR><TD CLASS="quote">well thats why im asking. i guess my question should of been is my fuel pump and ignition good enough for 500+? my goal is to hit 550.</TD></TR></TABLE>
Yes, your fuel and ignition should be good for that power..
Old Feb 4, 2005 | 07:33 PM
W.Zero's Avatar
Yes, your fuel and ignition should be good for that power..</TD></TR></TABLE>alright thx
Flashmn
Mar 14, 2009 02:06 PM
notforsteal
Dec 7, 2008 09:53 AM
JSpin
Feb 17, 2005 10:46 PM
4_door_teg
Sep 30, 2004 03:40 PM
Kwuaymaikrup
Sep 19, 2003 02:40 AM
