turbo manifold studs.......AFTER DRAG KIT!?!?!
hey all im taking my dragIII kit off and doing some improvements but when i put the drag kit on it cam with some bolts and the studs had to be taken out of the head on the exhaust side.......
now i am going to change some things namely a manifold how do i re stud the head??
or should i just use the bolts again?? i dont want any leaks because i think it is leaking now.
anyone had this issue???
Re: turbo manifold studs.......AFTER DRAG KIT!?!?! (mrbsponge)
You could use the same, but I like the Honda studs that come in the head. They worked very well w/my drag kit and I have had no leaks.
yeah im gonna look at keeping the old bolts vice putting in new studs, but how in the heck do you put new studs in a head, ive never done this before
Re: (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge »</TD></TR><TR><TD CLASS="quote">how in the heck do you put new studs in a head, ive never done this before</TD></TR></TABLE>
You can use two regular nuts (8mm x1.25 usually) locked against each other with 2 spanners. Then you can use a socket to drive the stud in. Once it's in you un-jam the nuts and spin the]nuts off by hand.
thanks, thats what i was figuring how it was odne, but i was owndering if there were any that were like the ARP style with the allen head deal things built in
