i need to tap my intercooing piping
* B A N N E D *
I need to tap my intercooler plumbing before the throttle body. If i drill a hole in it for air fitting will it thread in or what can I do to make this work.I drew a pic of the plumbing and a circle for where i want to tap it.
* B A N N E D *
Re: i need to tap my intercooing piping (m R g S r)
vaccum for catch can if you see in the pic the way they have it to the filter i was told that you can tap it anywhere before the throttle body
can you see my little add on after the intake manifold
Re: i need to tap my intercooing piping (crxvtecturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxvtecturbo »</TD></TR><TR><TD CLASS="quote">vaccum for catch can if you see in the pic the way they have it to the filter i was told that you can tap it anywhere before the throttle body
can you see my little add on after the intake manifold</TD></TR></TABLE>
you cant tap it to a port that sees boost.....best bet is to tap it to the turbo inlet...
* B A N N E D *
Re: i need to tap my intercooing piping (civicflnum1)
onmy turbo inlet i have nowhere to put it at i know where you are talking about but i have no fitting there can i drill one out or no?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxvtecturbo »</TD></TR><TR><TD CLASS="quote">onmy turbo inlet i have nowhere to put it at i know where you are talking about but i have no fitting there can i drill one out or no?</TD></TR></TABLE>
make a intake for ur turbo, drill a hold, weld a fitting, run a tube.
* B A N N E D *
Re: i need to tap my intercooing piping (radioren)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by radioren »</TD></TR><TR><TD CLASS="quote">or for that kinda port on the intake tube jb weld it. I know here come the ghetto jokes! lol</TD></TR></TABLE>
my friend told me to do that no ghetto for me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxvtecturbo »</TD></TR><TR><TD CLASS="quote">bump^
bro what else do u need to know? weld a fitting on ur intake for the turbo n run a hose to the catch can
I wouldn't plumb it that way.You will end up pulling oil and/or oil mist into your intercooler and throttle body.This is more an emissions type setup.Check the search feature about catch cans.There are a lot of nice setups people are using.
Glenn
Glenn
