Built engine+Smog testing
Old Feb 4, 2005 | 05:37 PM
snt78's Avatar
Default Built engine+Smog testing
I am wanting to know if an engine with a fully built bottom end will pass smog? Does the compression matter be it low, high or stock. Thanks
Old Feb 11, 2005 | 01:56 PM
snt78's Avatar
Default Re: Built engine+Smog testing (snt78)
Anyone have an answer to this question, or am I the only one that has reservations about building my engine due to legality issues? I have enough experience with turbo to tear down the set-up every two years, however, what is the use if the engine as a whole will never pass. Thanks
Old Feb 11, 2005 | 01:58 PM
Kwuaymaikrup's Avatar
I don't know anything about CA emisions but up here in WA you can pass with just about anything. My first LS/Vtec setup passed emissions with no cat and only 700 miles on it. It is basically all in the tune.
Old Feb 11, 2005 | 04:14 PM
jeremyG2teg's Avatar
My built motor (B18B w/8.8:1 comp.) has passed for 2 years.
This is the latest test slip...
Old Feb 11, 2005 | 04:21 PM
dustin's Avatar
It's going to pass just fine if you have stock cams and 0,0 gears.
The bottom end isn't going to affect smog much, if at all. Unless of course the engine is misfiring already and you have 3:1 compression heh.
Destructive-
Apr 11, 2010 05:23 PM
slimjimming6688
Dec 15, 2008 08:23 PM
gtz
73
Mar 13, 2008 07:22 PM
xplanetearth420x
Mar 9, 2004 07:13 PM
90da4dr
Nov 2, 2002 10:05 PM
