Must Dos for rebuilding your engine?
Hey guys I just pulled the b16 out of my crx. The pistons and rods and walls all looked to be in good condtion. I had a few questions on the rebuild.
How do i know if i can or cannot use stock bore forged pistons?
Where can I find wesico pistons or cp pistons for the best price?
what new parts do i need ? bearings? seals? pumps?
what do i all need checked at a machine shop?
what needs to be machined?
what are the tq specs on everything or should i have it assemblyed by a local shop?
thanks for all the help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NotPhilTran »</TD></TR><TR><TD CLASS="quote">Hey guys I just pulled the b16 out of my crx. The pistons and rods and walls all looked to be in good condtion. I had a few questions on the rebuild.
thanks for all the help.</TD></TR></TABLE>
Where do I start.. Its good to build your own engine if you have the knowledge to do it and are careful.. If your going to do a full rebuild I would get the block and head jetwashed and get the head milled true and cylinders in the block honed.. I would rebuild you oil pump and check the specs on it to make sure its still good..
Youll need new bearings, rings, head gasket, valve seals, and other gaskets and seals..
I just finished doing a complete rebuild on my B16 motor so let me know if you have any other questions..
Also, since you have you B16 out and apart, Check the allen key fitting on the bottom of the oil pump and tell me if there is a crush washer on there..
you need to mic the more with a bore gauge then go from there
look around search for a few places. i got mine from a local machine shop
get a complete gasket kit, do atleast rod bearings.
bores, clearances, cleanliness, vlave seats, head and block distortion
depends on how far you are goin. valve seats, deck surfaces
assy, isnt that hard get a helms and follow it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves »</TD></TR><TR><TD CLASS="quote">Where do I start.. Its good to build your own engine if you have the knowledge to do it and are careful.. If your going to do a full rebuild I would get the block and head jetwashed and get the head milled true and cylinders in the block honed.. I would rebuild you oil pump and check the specs on it to make sure its still good..
Also, since you have you B16 out and apart, Check the allen key fitting on the bottom of the oil pump and tell me if there is a crush washer on there..</TD></TR></TABLE>
ill have to check that tommrow after guard drill.
thanks for the advice. any more??
thanks for the advice. any more??</TD></TR></TABLE>
Read alot here on honda-tech and sort through all the bullshit and find the facts.. Talk to Earl here on honda-tech..
nice thread i found
http://www.boosted-hybrid.com/viewtopic.php?t=326
i think i will have a shop assemble my engine though.
Assemble it yourself man, $300-400 wel saved dollars
Take pictures and make threads, I built my own forged D16, took it to a shop only for some crank work, honed it myself, checked all clearances 10 times. You really do learn so much, took me about 15 hours when I had all the parts and Im **** as ****, was reading over and over the manual and making tons of threads on here with pics
Pretty easy
Search for a thread by Boosted-Hybrid, might actually be on Boosted-Hybrid.com, he took pics and meticulous detail of a GSR build. Was no use to me but might be good for you
DIY always gets a big
and the knowledge you gain is
Pretty easy
ha! I used that same thread by boosted hybrid
that and a few other threads and the Helms manual you should be all set.
I have all the part numbers of the OEM misc parts I needed to replace... Orings, dowel pins, washers, gaskets, etc... soon as I organize them I plan to make a thread.
that and a few other threads and the Helms manual you should be all set. I have all the part numbers of the OEM misc parts I needed to replace... Orings, dowel pins, washers, gaskets, etc... soon as I organize them I plan to make a thread.
Yes there is a crush washer under the allen plug.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 »</TD></TR><TR><TD CLASS="quote">ha! I used that same thread by boosted hybrid
I have all the part numbers of the OEM misc parts I needed to replace... Orings, dowel pins, washers, gaskets, etc... soon as I organize them I plan to make a thread. </TD></TR></TABLE>
I can see it now
that and a few other threads and the Helms manual you should be all set. I have all the part numbers of the OEM misc parts I needed to replace... Orings, dowel pins, washers, gaskets, etc... soon as I organize them I plan to make a thread. </TD></TR></TABLE>
I can see it now
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msmotorsports »</TD></TR><TR><TD CLASS="quote">
Yes there is a crush washer under the allen plug.</TD></TR></TABLE>
Strange, On all the diagrams for the 2nd gen B16 they dont show a crush washer there.. But for all other b-series oil pumps they do..
dpine
Sep 22, 2008 03:42 PM
Yambor
May 30, 2006 08:59 AM
