what to use to clean spark plugs?
Re: what to use to clean spark plugs? (backpurge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nlc »</TD></TR><TR><TD CLASS="quote">
simple green? what else</TD></TR></TABLE>
I answered in your other post.. why make another one..
But I second the carb cleaner, and then let them dry out a little bit... It always does the trick.
Re: what to use to clean spark plugs? (nlc)
Simple green? Are you kidding that will do no good for the plugs might as well dip them in water.
Bead blast them and then spray then blow then out with an air gun. Then spray some carb cleaner on them and blow them out again with the air gun.
Re: what to use to clean spark plugs? (underpressure02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 »</TD></TR><TR><TD CLASS="quote">
Bead blast them and then spray then blow then out with an air gun. Then spray some carb cleaner on them and blow them out again with the air gun. </TD></TR></TABLE>
My friend has a kick *** plug cleaner at his house.. all air operated... you can't beat it.. but carb cleaner will work to get it running.
why waste all the time cleaning them when a new set is under 10 bucks
just go buy a new set be easy and done.
Re: what to use to clean spark plugs? (b18bturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo »</TD></TR><TR><TD CLASS="quote">why waste all the time cleaning them when a new set is under 10 bucks
just go buy a new set be easy and done.</TD></TR></TABLE>
Cleaning them takes like a couple seconds with the right tools.
exactly.
exactly.
I agree. I get plugs for $1 a piece. Screw cleaning them. I replace them with every oil change.
Re: what to use to clean spark plugs? (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 »</TD></TR><TR><TD CLASS="quote">I agree. I get plugs for $1 a piece. Screw cleaning them. I replace them with every oil change. </TD></TR></TABLE>
at the jetties fishin'
Re: what to use to clean spark plugs? (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 »</TD></TR><TR><TD CLASS="quote">
Cleaning them takes like a couple seconds with the right tools. </TD></TR></TABLE>
even less time and tools needed to swap them with brand new ones.....durrrr
Yup! Under $10 for a new set. Heck, I have a bunch laying in my garage when I need them.
creator1322
09-14-2008 08:51 PM
JBirch_97Prelude
05-13-2007 04:45 PM
