A/c clearance
Old Feb 6, 2005 | 11:06 AM
forced00si's Avatar
Default A/c clearance
I have been thinking seriously about getting rid of my vortech sc for a turbo. I have picked out some basic parts but I need to know if it will clear my a/c and make the power that i crave (somewhere in the 350-400hp range and lots of torque) . The car is a 00 si b16a2 fal fan and all the stock accesories. The set up that I think that I want to use is an Inline pro mani and Gt30r. Please post pics if you have simular set up and tell me your hp range is. All input is apreciated. I am new to the custom turbo set ups, but I feel that I am ready to make it happen.
Old Feb 6, 2005 | 11:16 AM
_gurusan_'s Avatar
Default Re: A/c clearance (forced00si)
Glad you decided to get rid of the vortech....it's POS
Is your engine stock? I wouldn't go over 280 whp or so for daily driving if it is.
Old Feb 6, 2005 | 11:25 AM
forced00si's Avatar
Default Re: A/c clearance (_gurusan_)
when I make the sc to turbo change I have Wiseco pistons , eagle rods , valves springs ect.... If it wasnt for that Then I wouldnt change The vortech has been good to me for 3 years. I could have put a payne 8 rib pulley set on it to make more. I just refuse to loose a/c.
Old Feb 6, 2005 | 01:23 PM
forced00si's Avatar
anyone still got theyr a/c and makin good hp? what did you use to make it happen?
Old Feb 6, 2005 | 02:10 PM
sohcturbocoupe's Avatar
bump for a freind that need's some info
Old Feb 6, 2005 | 04:07 PM
forced00si's Avatar
Default Re: A/c clearance (sohcturbocoupe)
thanks for the bump
Old Feb 6, 2005 | 08:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcturbocoupe &raquo;</TD></TR><TR><TD CLASS="quote">bump for a freind that need's some info</TD></TR></TABLE>
Old Feb 6, 2005 | 11:20 PM
turbopimp's Avatar
There's no reason whatsoever to lose ac with a turbo set up... most people that don't have ac with their turbos remove it for weight savings or to clean up the engine bay, not because they must.
Old Feb 7, 2005 | 03:29 AM
liam821's Avatar
25 Year Member
Default Re: A/c clearance (turbopimp)
Full-race makes a nice a/c turbo kit.
Old Feb 7, 2005 | 03:53 AM
97dxnut's Avatar
Default Re: A/c clearance (liam821)
neukin will be coming out with an equal length a/c compatible mani. $650 i think
Old Feb 7, 2005 | 05:12 AM
CRVRX's Avatar
Default Re: A/c clearance (97dxnut)
With an Inline Pro manifold and a T3 5 bolt turbine housing you will have plenty of room for a 3" down pipe and AC.
You will also have room to run a fan , a full size radiater and even and intake ! ( Which seems most turbo people don't use anymore) and make your power goal with room to spare.
Old Feb 7, 2005 | 04:03 PM
forced00si's Avatar
Default Re: A/c clearance (CRVRX)
Thank you for all the positive responses! I knew it could be done. There is so many kits, well mani setups that wont work with ac I was kinda woried about the one I wanted(inline pro). Again thanks for the help in my quest to go very fast and not sweat in the hot summer.
Old Feb 7, 2005 | 04:56 PM
numbnuts22715's Avatar
Not trying to steal your post, but I dont wanna make a new thread on it... Ive been asking the sponsors in the forum marketplace if their turbo kits will fit a 92 cx hatch with a b18c and still retain the a/c... a lot of them tell me no... Do you guiys know of any premade kits that I can use and retain my a/c? I dont think I feel confident enough with building my own.
Old Feb 7, 2005 | 05:52 PM
blackANESE's Avatar
Default Re: (numbnuts22715)
Not quite the same set up as to what you are asking but similar
Its a revhard manifold with a Precision sc61 with S housing.
I had to get a slim fan and make the condensor fan a pusher style. I had to use a slim fan on the radiator but its still mounted on the front
Old Feb 7, 2005 | 06:34 PM
forced00si's Avatar
Default Re: (blackANESE)
Thanks for the pic. Hows it drive and what kinda hp does it make?
bloodtyper
Oct 26, 2011 07:05 PM
kingsize215
May 4, 2011 06:45 PM
HUGATO2002
Sep 9, 2009 02:45 PM
MugenMike
Feb 27, 2007 01:04 PM
