BENSON ENGINE NEED HELP????????
Old Feb 3, 2005 | 08:01 PM
dohcguy's Avatar
Default BENSON ENGINE NEED HELP????????
Hello my name is Sean,
I bought a block from a friend that Benson built for him. Well im having some trouble. I put it in and it smokes a bit. So we took the engine out and found out that we need some piston rings. Well i have been going through a lot to find HELP!! It is a d16a vtec with a 78mm bore and cp pistons.. I have called just about everyone... Called cp pistons, Benson, another guy that cp referd me to .... and everyone one i talk to needs the paper work on the pistons... I dont have any. I talk to the guy who i bought the engine from and he said that he doesnt have paper work.... Im kind of stuck.... can someone please help me sorry
Old Feb 3, 2005 | 08:02 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: BENSON ENGINE NEED HELP???????? (dohcguy)
pm earl, he should be able to help you
Old Feb 3, 2005 | 08:07 PM
93turbo16's Avatar
Default Re: BENSON ENGINE NEED HELP???????? (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">pm earl, he should be able to help you</TD></TR></TABLE>
I think if you don't have the paper work, you will have to go through someone other than a company, b/c they can be bastards. Usually individuals on here are more of a help.
Old Feb 3, 2005 | 08:13 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: BENSON ENGINE NEED HELP???????? (93turbo16)
just a thumbs up? you gotta work harder than that to get your post count up.
Old Feb 3, 2005 | 08:18 PM
93turbo16's Avatar
I'm not the one with the 9 post per day rate.
wantboost's Avatar
Who is Mr Robot?
actually its 9.05
i just thought of another person. you could pm camp1320 he could probably get you the rings
Old Feb 3, 2005 | 09:18 PM
donkiman's Avatar
if you find the size of the piston, shouldnt you be able to buy piston rings that size?
Old Feb 3, 2005 | 10:01 PM
earl's Avatar
Default Re: BENSON ENGINE NEED HELP???????? (donkiman)
Are you positive they are 78mm pistons? That is HUGE for a D block. Take a ruler and measure across the top of the block to make sure it looks close to 78mm's. I can get you whatever size rings you want but 78 just does not sound right.
I will ask Benson if he has ever done a 78 block.
Old Feb 3, 2005 | 10:29 PM
dohcguy's Avatar
Default Re: BENSON ENGINE NEED HELP???????? (earl)
THANX I WILL MAKE SURE TOMORROW!!!
ALSO IF IT HELPS YOU I COULD SHIP YOU THE OLD RINGS????
XarupS
Oct 6, 2014 03:59 AM
blu3g
Jun 26, 2005 07:07 PM
axislucas
Apr 15, 2004 11:41 AM
Cyber ITR
Jan 29, 2004 09:48 AM
kaj
Jan 24, 2004 06:56 PM
