Missing link question
Old Feb 4, 2005 | 05:08 AM
CarpAngler's Avatar
Default Missing link question
This may be a dumb question and i did search and didnt really find a direct answer. I know that the stock map sensor will only read up to 11psi then after that the computer reads zero so you are getting no fuel for the added boost. With the missing link, is the map sensor still only good to 11psi?
After 11psi is the computer not going to compensate for extra boost after 11psi?
How many psi is the map sensor good for?
TIA
Old Feb 4, 2005 | 05:20 AM
TurboLude97's Avatar
Default Re: Missing link question (lude975)
the missing link will bleed off all of the boost so the map sensor wont see any. although it can handle up to 11 psi the stock ecu will throw a code if it sees any positive pressure.
Old Feb 4, 2005 | 05:30 AM
CarpAngler's Avatar
Thanks a lot
nicktagz
Sep 8, 2006 11:01 AM
redlseg
Apr 26, 2005 07:20 AM
94greddycivic
Jun 29, 2004 10:51 AM
01ITR#700
Mar 4, 2003 12:17 PM
schwett
May 15, 2002 01:01 PM
