need some help guys....
Old Jun 4, 2005 | 06:31 AM
EK_GSR's Avatar
Default need some help guys....
my problem is a bit weird..... at idle my car will stay on as long as its cold, but as soon as it gets into the warm state it shuts off. i mean its not a straigt shutoff its gradual.. as in it stutters for a second and then it turns off a couple seconds afterwards.
Im thinking its the dizzy, i already swapped out the coil so thats not it.... so any idea's ?!?!?
Setup:
Hondata S200B w/ P28
B18C fully built
CP pistons 9:1 dished
Eagle Rods
Port / Polished Head
Full Skunk Valve train w/ Stock GSR cams
Skunk 2 intake manifold
Greddy catch can
Greddy 18G turbo kit w/ upgraded greddy I/C & charge piping
DSM 450cc Injectors
FPR
lightened flywheel / 4 puck unsprung ACT / ACT heavy duty pressure plate.
Old Jun 4, 2005 | 03:57 PM
kell211's Avatar
Default Re: need some help guys.... (EK_GSR)
i would start checking sensors. iacv, fiv, coolent temp sensor, etc. things that change voltage when the car gets warm.
Old Jun 4, 2005 | 06:44 PM
hybridsol's Avatar
Hondata.
I had it too, for the longest time running my B18C w/skunk 2 intake. Go through the idle adjustment stuff listed on their web site- it helped some, but it would still "die out" after the car was war, esp after it was sitting all night.
Good luck.
Old Jun 6, 2005 | 04:26 AM
EK_GSR's Avatar
Default Re: need some help guys.... (hybridsol)
thanks a million guys, i will try everything... its frustrating because it was working fine beore i put hondata on and all of a sudden the car started taking a **** on the dyno while it was idling.... i mean im not going for crazy power its just for me to drive to work and school since the drives sometimes are long so it makes it funner with the hatch, but i mean i will try going and using the crome chip, and see if it works again...
THANKS !!!! more idea's keep 'em coming guys !
zxstrikerxz
May 23, 2007 10:00 AM
Pfieff
Jul 19, 2005 09:39 AM
EK_GSR
Jun 10, 2005 04:02 AM
BoOsTiN Dc2
Dec 20, 2003 08:18 PM
2000Si-at-UK
Apr 10, 2002 09:38 AM
