blowing oilpan gasket
for some unknow reason i am blowing out my oil pan gasket. my pvc valve is not hooked up it is just venting to the open. my compression is 205 205 222 222. i replaced the oilpan gasket and it blew out again how do i fix this?????????????
Re: blowing oilpan gasket (SoSlo)
fix the source of your blowby? It looks like your compression in two of the cylinders is a good bit lower than the other two.
Re: blowing oilpan gasket (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">its probably not venting very efficienctly unless he has a good pcv setup. </TD></TR></TABLE>
i bet ur right
i bet ur right
Re: blowing oilpan gasket (PrettyLude)
yea and if something is fucked in the block and you are getting massive blowby then its really bad that its not venting right.
the only problem with that is that it had enough pressure to blow the gasket all teh way out from between the oilpan and the block. i did a leak down and it held up to 90psi with minimal leak.
Btothe3rdDegree
08-20-2003 06:26 PM
