Boost problem
Old Jun 7, 2005 | 08:06 AM
dranican's Avatar
Default Boost problem
I was boosting 8.5psi 2 days ago.
Today i take my car for a spin. and it doesn't go past 5.5 - 5.8psi and at the high rpms the boost starts to lower.
Can anyone help me ??
Old Jun 7, 2005 | 08:26 AM
Mik3's Avatar
Default Re: Boost problem (dranican)
i dont know too much but ill take a wild guess and say the wastegate is opening to soon?
Old Jun 7, 2005 | 10:21 AM
dranican's Avatar
So what can you do to fix that ?
Old Jun 7, 2005 | 10:27 AM
Blaze45's Avatar
Brrraaaap!
Default Re: (dranican)
99% sure its a boost leak. Are you running internal or an external wastegate?
Old Jun 7, 2005 | 10:37 AM
dranican's Avatar
external wastegate.... deltagate
Old Jun 7, 2005 | 11:00 AM
meltman1234's Avatar
Have you messed with it? My car was doing something like that because the head on the wastegate was loose.
Old Jun 7, 2005 | 11:19 AM
dranican's Avatar
I haven't touched it after the tuning.. I did like 6 runs with 8.5psi..no problems.... I took it out the other day... and just poof...5.8psi... just like that
Old Jun 7, 2005 | 01:22 PM
Jcup315's Avatar
Default Re: (Blaze45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">99% sure its a boost leak. Are you running internal or an external wastegate? </TD></TR></TABLE>
I would have to agree...check for a leak
Old Jun 7, 2005 | 01:26 PM
Highrevs99's Avatar
WG gasket is leaking or charge pipe leak , check WG gasket first .
Old Jun 7, 2005 | 01:29 PM
allanonjj's Avatar
Default Re: Boost problem (Highrevs99)
I think its the thrush bearings!!
Old Jun 7, 2005 | 02:06 PM
Highrevs99's Avatar
Default Re: Boost problem (allanonjj)
Yep, is those darn thrust bearing again . Oh and how is Allan ?
Old Jun 7, 2005 | 02:13 PM
BlackCRX's Avatar
what kinda intercooler are you running ??
my friend had the same problem
t25 on a z6 making 11psi, cracked intercooler and he was making 4ish psi
another friend with the same setup had the bov loose and was making 9psi down to 5psi
Old Jun 7, 2005 | 02:32 PM
dranican's Avatar
I just have a normal sized intercooler..I was just on the highway.. and now it doesn't boost in the 1st and 2nd gear and in the 3d gear it goes to 4psi.... heellpppp
Old Jun 7, 2005 | 03:01 PM
Blaze45's Avatar
Brrraaaap!
Dude check for a boost leak! Then if you donthave a boost leak, Im willing to bet that its your deltagate, they are not the best WG from what I have herd and read... See if you can sell it and pick up a tial?
Old Jun 7, 2005 | 03:38 PM
musclefella's Avatar
Call me tomorrow we'll take everything off and put it back together again. No worries it's probable something small like a leak or something.
I think it's the wastegate as well, we'll see.
Old Jun 8, 2005 | 02:32 PM
Default Re: (musclefella)
Problem solved, intercooler pipe was loose.
Lock thread
B16-CRX
Dec 23, 2006 06:34 PM
93turbo16
Sep 14, 2005 11:15 AM
ldanphanl
Aug 23, 2005 05:31 PM
specie
Feb 5, 2004 09:38 AM
Fired Honda
Jul 18, 2003 05:42 AM
