Misfire CEL 74 Help!
Old Jun 3, 2005 | 05:28 PM
b00sted4dr's Avatar
Default Misfire CEL 74 Help!
Ok im getting a misfire cel 74. My car drive and feels normal. I have no idea what is causing this cel. I have changed distributor cap and switched to another working dirstirbutor. I have changed new spark plugs and new spark plug wires.
I swapped around the injectors and still i get this CEL!!! When im using the obd1 ecu, i get no cel. Its only when i run the obd2 ecu.
Compression checked out good.
This all happened when i went back to stock from being boosted.
I want to install my setup again and get it tuned, but i would love to find out whats tripping the obd2 ecu.
Help me get boosted again
Old Jun 4, 2005 | 04:33 AM
b00sted4dr's Avatar
Default Re: Misfire CEL 74 Help! (b00sted4dr)
Old Jun 4, 2005 | 01:25 PM
b00sted4dr's Avatar
TTTTT
Old Jun 5, 2005 | 02:53 PM
Vera's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00sted4dr &raquo;</TD></TR><TR><TD CLASS="quote">TTTTT</TD></TR></TABLE>
help this guy out
iv got random misfires i cant figure out ethier
iv replaced cap rotor injectors plugs and wires !
bump bump
Old Jun 5, 2005 | 04:49 PM
b00sted4dr's Avatar
Default Re: Misfire CEL 74 Help! (Vera)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vera &raquo;</TD></TR><TR><TD CLASS="quote">
help this guy out
bump bump</TD></TR></TABLE>
For reals. Ive seen threads on here with people having the same problem. But the sad part is, it seems like no one ever gets a solution...
I wonder if its just a sensor?
Old Jun 5, 2005 | 05:16 PM
Vera's Avatar
from what iv been reading ..... things that might cause this ....
bad coil / ignitor
valve lash adjustment
in some werid cases the IAC was replaced and solved problems
i unpluged my iac and it seems to be working good ..
have no tested my coil yet
and my valves i think need adjustment
not sure if it would cause this .. but just from searching countless threads
Old Jun 5, 2005 | 08:44 PM
b00sted4dr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vera &raquo;</TD></TR><TR><TD CLASS="quote">from what iv been reading ..... things that might cause this ....
bad coil / ignitor
not sure if it would cause this .. but just from searching countless threads </TD></TR></TABLE>
I think im going to try and adjust my valves. I really hope this is it.
Good luck to you too bro
Old Jun 5, 2005 | 09:24 PM
Vera's Avatar
Good luck to you too bro </TD></TR></TABLE>
thanx .. good luck to you as well
i ll be testing my coil sometime this week
and picking up a fuel filter.. (never know hah migh do so good ?)
and hopefully get my valves adjusted before the week is over!
Old Jun 23, 2005 | 09:17 PM
Vera's Avatar
anything ever happen ?
iv still got misfires
ended up putting a whole brand new dizzy on / fuel filter replaced /....compression test came out good .....
the one thing i have not checked is fuel pressure ... and it seems like its my last option ? heh
kaotikvizion
Jun 3, 2008 11:19 PM
BLacK FirE
Jul 13, 2006 01:56 PM
b00sted4dr
Jun 26, 2005 06:39 AM
b00sted4dr
Jun 2, 2005 08:12 PM
spooned out
Mar 21, 2005 04:28 PM
