oil leck in the spark plug tube
ok i have an 2000 civic turbo d16y.........the first spark plug gets gettin oil in it...i have replaced the gasket on the head cover and use hondabond to seal it around the outside of the gasket and im still getin a leck......can some one help me?
Re: oil leck in the spark plug tube (civicxspower)
the valve cover has seals on the bottom of them. they are called spark plug hole seals. i work for dodge and i had the same problem with a neon. was doing a tune up on it and the plugs i pulled out were dripping with oil. removed the valve cover, and replaced the valve cover spark plug seals. that took care of the problem.
denierlexiese
08-17-2015 07:03 AM
