Problems with spooling and full boost
Old Jun 4, 2005 | 05:06 PM
zseeanz's Avatar
Default Problems with spooling and full boost
I have a d16 with a gt28 running 10psi. I'm having some issues hitting full boost. The turbo starts to spool about 2.5K, which is fine. Problem is, I'm not hitting 10psi till about 6K. Shouldn't it be hitting full boost in the 4-5K range? I've already tighted manifold bolt, checked all vac lines, tightend all clamps, checked all couplers, and checked waste gate. Everything looks good. Any other ideas? Could it be my MBC?
Old Jun 4, 2005 | 05:59 PM
zseeanz's Avatar
Default Re: Problems with spooling and full boost (zseeanz)
nobody can help me out?
Old Jun 4, 2005 | 06:02 PM
a1320addict's Avatar
got a gt28r too....internally gated having the same issues.....is yours internal or external?
Old Jun 4, 2005 | 06:19 PM
zseeanz's Avatar
Default Re: Problems with spooling and full boost (yehiknowrite)
it's internal. You got a MBC?
Old Jun 4, 2005 | 06:29 PM
nope...i think its the wastegate....this is the third instance ive heard of..excluding mine...have you tried adjusting the actuator rod?
Old Jun 4, 2005 | 06:40 PM
zseeanz's Avatar
nope, haven't touched the actuator arm. I don't wanna mess anything up
Old Jun 4, 2005 | 07:26 PM
BlueShadow's Avatar
I think that with internally gated turbos you'll usually have your WG connected right to the compressor housing. With the WG hooked up to a boost source that close you're boost level is lower then what it is supposed to be. The reason is your WG is opening a lot earlier and it seems more responsive or twitchy, (whatever you wantto call it) when ever the boost changes.
Are any of you guys using EBCs?
Old Jun 4, 2005 | 07:34 PM
zseeanz's Avatar
Default Re: Problems with spooling and full boost (BlueShadow)
My wastegate's hooked up to my intake manifold. Nope, no EBC here. I'm using a MBC.
Old Jun 4, 2005 | 09:44 PM
my internal gate's vacuum source is righto the the compressor housing fitting that was supplied with it.
im not running any form of a boost controller....im debating fixing it by having the wastegate flapper port in the turbine section ported
061000rr
Jun 14, 2011 04:37 AM
madracer
May 21, 2009 02:36 PM
ivt-t
Apr 21, 2007 06:13 PM
ALL IMPORT
Aug 18, 2006 08:05 PM
