my 380 whp h22 wants more power...how about a T-61
i am making 380 whp off of a t3/t4oe 60 trim turbo w/ a .63ar t31 turbine section..
but the power band is awsome
see here run done at 18psi:
i would like to have a very similar power band but with more whp of course..
goal would be around 450 whp with good strong torque like 375wtq..on pump gas
i don't think my 60 trim will take me there..so i have been looking through different options and i really like the t3/t61 turbo with a .63ar stage 5 turbine
experts??? or
experts??? or
Re: my 380 whp h22 wants more power...how about a T-61 (graphic)
have you ever thought about going with a bigger turbine housing. I know the T3/T4 60 trim can do 450whp. going with a bigger turbine housing your going to get a little bit more lag but it a cheaper alternative. just a throught.
Go with a sc61 if you dont want much more lag, but more overal power capability. You could also check out a gt3767 with a t3 turbine side. These are good for over 600whp.
Regards,
Justin
Regards,
Justin
Re: my 380 whp h22 wants more power...how about a T-61 (2000civicsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000civicsi »</TD></TR><TR><TD CLASS="quote">have you ever thought about going with a bigger turbine housing. I know the T3/T4 60 trim can do 450whp. going with a bigger turbine housing your going to get a little bit more lag but it a cheaper alternative. just a throught.</TD></TR></TABLE>
meaning using a .82 a/r w/ a stage 5 wheel???
also i would like to achieve this on 93 pump gas...
now if i were to get the t3/t61 with a .63 a/r turbine housing and stage 5 exhaust wheel
how bad at the same boost levels(18psi) would my spool time be?
off 1000rpm?
anyone w/ a t3/t61 on a h22 dyno??
off 1000rpm?
jetlude
12-27-2006 07:49 AM
hondaracin24
12-12-2006 01:54 PM
