Head Gasket
Old Jun 6, 2005 | 08:44 AM
Little Rascal's Avatar
Default Head Gasket
I am just finishing up my build up on a d16z6..and im gonna use a stock head gasket....but i wanna lower the compression alittle more by using a head gasket shim..just wondering if anyone has used one on here before and or heard anything bad about them. did a search for it and it is temp. down for right now...any comments welcome
Old Jun 7, 2005 | 07:20 AM
Default Re: Head Gasket (Little Rascal)
bump....anyone?
Old Jun 7, 2005 | 08:21 AM
RyanEJ8's Avatar
How do you plan on lowering compression with the stock headgasket????
I'm not sure I understand your question.
Old Jun 7, 2005 | 08:37 AM
Default Re: Head Gasket (RyanCivic2000)
was gonna use a 30thousands shim on top of the head gasket to raise up the head alittle more instead of using 2 head gaskets or paying 100+ for a little thicker one then stock..
Old Jun 7, 2005 | 08:50 AM
RyanEJ8's Avatar
Oh I see. I missed the part about the shim there. I'm not really sure of anyone that has tried that with a D16 hg.
Old Jun 7, 2005 | 02:34 PM
ehh alright...hope someone else see's this and maybe they can offer an opinion
Old Jun 7, 2005 | 03:30 PM
Turbo E's Avatar
ok so you're not gonna use a HG? and use a "shim" instead?
I'll assume you mean to fit the shim between the layers of the OEM HG. because otherwise Expect a lot of headaches in your efforts to save a few $.
IMO do it right. Learn from other's mistakes, not yours
Old Jun 7, 2005 | 04:52 PM
no no no....still gonna use the stock headgasket(it is new) but just had this shim laying around from a couple years ago for my old civic and i figured i would try it since i never did in my last car...they use them all the time on v8 junk and if i use head studs to keep the head from lifting under boost, it should be fine i would think....anyone out there ever used one on a d16 or any honda engine for that matter?
Old Jun 7, 2005 | 06:07 PM
beerbongskickass's Avatar
I would worry more about important things like tuning than a "head gasket shim" whatever that is...
Old Jun 7, 2005 | 08:54 PM
Default Re: Head Gasket (beerbongskickass)
was just trying to get some opinions..i have all the other stuff IE.. hondata, fuel pump, injectors, etc....but i wil just use the normal HG and it should be fine from doing some reading but thanks to the people who tryed to see where i was trying to go
Old Jun 7, 2005 | 09:29 PM
integlspwr2k's Avatar
ive never herd of a hG shim before.
if you can explain or elighten us that would be great.
Old Jun 8, 2005 | 07:18 AM
Default Re: Head Gasket (integlspwr2k)
machine shops use a head shim when they get a engine in and the head is warped but they can save it by shaving it down till its flat again and then using the shim to still get the clearance it needs while still using a regular head gasket...so in theory..i can still do this even though my head is still good.....so i can get the little bit lower compression ,without stacking 2 head gaskets....i dont look at it as a short cut...just another option thats all
Lx Civic 99
Dec 31, 2013 05:50 PM
dc4teg95
Dec 31, 2010 05:44 PM
CoreyR
Sep 22, 2004 11:02 PM
filetofit
Aug 13, 2002 08:49 PM
