Turbo stopped boosting at track
Old Jun 5, 2005 | 11:51 PM
crx88fast's Avatar
Default Turbo stopped boosting at track
I went to the track yesterday for the first time with my boosted crx. My first run i had boost in 1st gear but when i hit 2nd there was no boost. so i backed off and thought i blew a charge pipe but wheni checked all the pipes were fine. tried another run and nothing. checked turbo and no shaft play, and its spinning. when i left i disconected the wastegate to see if that was it, and i got boost for just a second then it went back down to zero. i didnt get a chance to mess with it much anymore but what should i be looking for as the cause of the problem?any help is appreciated thanks
Old Jun 6, 2005 | 01:01 AM
sporkcrx's Avatar
Default Re: Turbo stopped boosting at track (crx88fast)
Chances are you have a leak, even though you checked it over. Check every connection again, just because the connector is over the pipe doesn't mean it's sealing.
Old Jun 6, 2005 | 11:11 AM
crx88fast's Avatar
Default Re: Turbo stopped boosting at track (sporkcrx)
im gonna go check the connections again really good , but is there anything else that would cause this?
Old Jun 6, 2005 | 11:22 AM
notoriousB's Avatar
lack of oil pressure will cause the turbo not to spool as well, hopefully that's not it...
97boostedteggy
Apr 18, 2016 11:39 PM
allmotor_dm
Jan 24, 2006 06:07 PM
RFd15bhatch
May 24, 2005 12:27 PM
andyman97
Dec 28, 2003 01:43 PM
xXx Justin xXx
Dec 4, 2002 09:27 PM
