How long will my turbo motor run?
I am thinking of turbo charging my 1994 honda civic ex but i need to know how many miles my motor will run after that .....Will it be reliable?
Re: How long will my turbo motor run? (SOHCsleeper)
relability is relative.
You can build a great bottom end, not tune it properly and ruin it
you can also
boost a stock bottom end, get a good tune, get good numbers and drive for tens of thousands of miles
you can also
Risky Business
Re: How long will my turbo motor run? (specv5150)
What he said..
Conservative power levels...and a conservative tune...your motor will run forever
If you're gonna run 12 PSI with a T3/T04 and a 13:1 AFR then don't expect it to last forever
Re: How long will my turbo motor run? (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">What he said..
If you're gonna run 12 PSI with a T3/T04 and a 13:1 AFR then don't expect it to last forever</TD></TR></TABLE>
arent you turbo and running the AFC Hack for some thousands of miles right?
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specv5150 »</TD></TR><TR><TD CLASS="quote">
arent you turbo and running the AFC Hack for some thousands of miles right?</TD></TR></TABLE>
Was on AFC hack, now on uberdata basemap. I've been boosted for about 10k, when I turboed I had 180,000 miles...and its still running great
that question is like asking when are you going to die? No one knows when but you have to take care of your body, feed it the right foods and stay out of trouble. Same applies to your turbo'd car. You have to do regular maintanence like change the oil, feed it good gas and keep the engine healthy.
DO a complete tune-up, change all belts, maybe even rebuild it, gasket kit and bearing kit. Then boost it, dont get all boost crazy, invest in a nice ecu or go uberdata/chrome, find someone that knows what their doing in your area and your set.
Was on AFC hack, now on uberdata basemap. I've been boosted for about 10k, when I turboed I had 180,000 miles...and its still running great </TD></TR></TABLE>
Yeah the AFC hack worked well for me, I just jumped to conclusions and ripped everything off and sold it. Looking back, all I needed to do was adjust the timing at the dizzy and invest in some ARP's....I am going to run uberdata this time...I might actually run the hack again though....not sure. I have a basemapped P28, just not sure if I want to tune and burn chips myself or run the hack since I dont plan on going past the map sensor limit
SOHCsleeper
12
06-06-2005 09:23 PM
