help car run like shit sound like lawnmower
help car run like **** sound like lawnmower
setup
stock gsr head
b16 bottom end aebs sleeves
je 9:1 pistons
eagle rods
stock injectors
p72 ecu
compression is 160 160 160 160
fuel pressure is at 48
car wont hold idle just dies. when i hold the gas to keep the car on it sound like a lawn mower. I get a code for o2 heater and IAT.
stock gsr head
je 9:1 pistons
eagle rods
stock injectors
p72 ecu
Re: (dunkd)
fire order is correct. ive check it serveral times. crank pull and cam gear are all line up at tdc. Should i pull the crank pull off and line hte gear up with the mark on block??
