Tial 7.25+3.63 spring = 11psi est ?
I read that you can add springs to eachother to raise the boost to the desired amount.
But then I read you can only mix a big spring with a small spring.
Anyone confirm this ? I just ordered the 3.6 spring to add to my 7.25 spring.
And it seems now I am assed out.
Any feedback is appreciated.
Re: Tial 7.25+3.63 spring = 11psi est ? (Dr. D-Series)
I didnt know they had multiple sized springs.
But while talking with LoveFab they did say you just added multiple springs to achieve anything over 1 bar I believe it was. So I would guess you are OK.
Well the 11.6 bar spring might screw with my stock map sensor. So I just wanted to play it safe.
I have an el cheapo MBC and it just spikes and bleeds back down.
And dont wanna pay 75 for a new turbo xs one.
The new spring cost me 13 bucks.
Thanks for the info. Much appreciated.
you have to get a big+small spring to do that.
sounds like you have a "small green 7.25psi spring" and you just bought a "small yellow 3.63psi spring"..........you cant mix those togeather......they will not fit in the wastgate.
you can only mix the small springs with the large springs. http://www.tialsport.com/wgspringapp.html
if you want to try and keep it under 11 psi look around for the "big yellow" spring rated at 10.1psi
Short Round
11-12-2003 10:16 PM
Superhatch
10
02-08-2002 06:59 PM
