2.0l w GT30R Dyno Results
Just to keep you people building motors motivated... After a long tedious rebuild from a bearing spinning, the results are undeniably enough to put a smile back on my face. The setup is as follows: (For those who are going through the pain, keep ya head up!)
84.5mm ITR Motor
CP 9.1 Pistons
Manley Rods
OEM Bearings
PR3 ITR Cylinder Head with .5mm oversized black nitride coated valves Swirl, ported polished, 3 angle valve job
Hondata IM Gasket
JG Edelbrock IM
70mm TB
Full Race Manifold & DP
GT30R w/ .86 ar
Precision 880 CC injectors
PWR IC
Tial 50mm BOV
Tial 40mm WG
Greddy Profec B Spec I
The first graph is C16 Race fuel @ 24 psi
The second graph is 14-15 psi with pump gas
@18 PSI on pump gas it did 475 hp and 320tq
The 3rd graph is my old setup with 750cc injectors and a T3/60-1 with a .63 ar
Modified by jdmvtec28 at 10:49 AM 6/6/2005
Modified by jdmvtec28 at 10:52 AM 6/6/2005
84.5mm ITR Motor
CP 9.1 Pistons
Manley Rods
OEM Bearings
Hondata IM Gasket
JG Edelbrock IM
70mm TB
GT30R w/ .86 ar
PWR IC
Tial 50mm BOV
Tial 40mm WG
Re: 2.0l w GT30R Dyno Results (B20TDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20TDC2 »</TD></TR><TR><TD CLASS="quote">great #'s what ems are you useing
great numbers on pump gas, what coating did you have done on the full-race manny
Re: (Makdaddynuge)
The coating on the Manifold is Swaintech ceramic, it ran about $190 and was gone for about 2 weeks. I must say it does an excellent job of keeping the underhood temps down, before without it I could see the oem hood begining to warp from the heat of the mani, hopefully the issue is now resolved. The EMS that was used was Neptune, and the tune was performed by Evan's tuning.
Re: (Makdaddynuge)
Very nice! Sorry I didnt get to stick around until the end, but the car sounded awesome on the dyno. Anyway, nice numbers ...should have some better graphs up tomorrow night when Jeff grabs them off the dyno pc.
Re: (redturbocivic)
I feel your pain... as soon as I spun the bearing I had all the parts to the machine shop within 5 days. It took them about 11/2 months to rebuild due to how busy the shop is during this time of year. The wait was worth it. Have faith.
Re: (jdmvtec28)
Definitely impressed by the results, Brian. While I was only at the shop briefly on Saturday, I must say that it was nice to finally see the car that I'd been ordering so many parts for
Good luck with it and have fun!!
Re: (GT35R_K20a2)
You, Jeff, and Phil must never sleep... It was nice to meet you as well, and I cannot thank you enough for working me into the schedule in a timely fashion.
Re: (Boostfed.com)
Thanks, and to everyone who doesn't know... Terry and boostfed is the truth, you can't &^%$ with his customer service or his prices.
Re: (jdmvtec28)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmvtec28 »</TD></TR><TR><TD CLASS="quote">Thanks, and to everyone who doesn't know... Terry and boostfed is the truth, you can't &^%$ with his customer service or his prices. </TD></TR></TABLE>
Thanks!!!!! That means alot to me!
Re: (Boostfed.com)
nice number brian
i've already bought two previous turbos from you, let me know when u sell this one haha.
also, coincidentally, i just finished my build a couple months ago, after losing my last motor to a spun bearing.
Re: 2.0l w GT30R Dyno Results (jdmvtec28)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmvtec28 »</TD></TR><TR><TD CLASS="quote">Just to keep you people building motors motivated... After a long tedious rebuild from a bearing spinning, the results are undeniably enough to put a smile back on my face. The setup is as follows: (For those who are going through the pain, keep ya head up!)
ohhh I know the pain, nice numbers on pump!! good motivation. My head's been down for a while now... might have my car running sometime this year.
that white ceramic coating is almost scary looking.
84.5 mm - guessing this block is sleeved as well? didn't see that listed.
Re: 2.0l w GT30R Dyno Results (11psiTurboSI)
Sorry, I don't know what I was thinking when I typed that... the manifold is a JG Edelbrock piece... The coating on the manifold is the Swaintech header coating, it ran about $200 and 2 weeks for the application. It does an excellent job to keep underhood temps down. Just to clarify I am running a GT30R with .86 ar. I have modified the post and added my last dyno run with the 60-1 for comparison purposes.
Re: 2.0l w GT30R Dyno Results (HitEm'Up)
Are any of the FI people out there running a vacuum system with their crankcase evacuation systems???
Re: (ITSME4G63)
475 WHP on pump gas is filthy, especially with a GT30R. Just goes to show you how much of a difference a ported head and some well selected parts makes when a lot of people running T3/T67's can't make that much on pump gas.
Re: (b16sedan)
Part I agree, I feel the headwork had a lot to do with the power that it was making... the timing was ultra conservative in the midrange and on top so it is not like I was forcing to the motor to do something it did not want to.
