where can i get a oil sandwich adapter?
where can i get one of these? i been readin if you tee off the block and havin the oil sender on it....it can snap? help wanted assap thankyou
Re: where can i get a oil sandwich adapter? (boosted2cam)
I have used both the Tee'd off Oil sender (The one that Tunertoys sells) and the Golden Eagle sandwich plate. I liked both and they both did there job very well. I prefer the Tee over the plate though now.
http://www.tunertoys.com
http://www.goldeneaglemfg.com
You can get both products through those links.
Re: where can i get a oil sandwich adapter? (hondaguyef)
mine is already tee off nothing bad has happen i been boostin only 5psi tho plannin on boostin 15psi i was just scared if might snap just cuz of more boost....thx for links
summitracing has one for about $30 last time i looked but deciding on going with a firewall mount setup using a t fitting and a line and a couple fittings from mcmaster.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted2cam »</TD></TR><TR><TD CLASS="quote">mine is already tee off nothing bad has happen i been boostin only 5psi tho plannin on boostin 15psi i was just scared if might snap just cuz of more boost....thx for links </TD></TR></TABLE>
Boost pressure will not have any affect on oil pressure.
Question about oil sandwhich's
I ha ve my oil feed off the T on the back of the block, i w ant to run an oil pressure gauge.
is it smart to run oil to turbo from the block and oil pressure from the sandwhich?
or is my reading going to be off?
Re: where can i get a oil sandwich adapter? (NotPhilTran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NotPhilTran »</TD></TR><TR><TD CLASS="quote">Question about oil sandwhich's
or is my reading going to be off?</TD></TR></TABLE>
I'm pretty sure you can have it(oil pressure gauge sender) at either spot and the reading wil be the same. I have mine on the Tee
pgpunkguy
07-01-2011 12:51 PM
integra-modder
07-07-2004 08:19 AM
