waste gate issue
Old Jun 7, 2005 | 04:35 AM
ITRnorway's Avatar
Default waste gate issue
can anyone brief me about what size is the best from TIAL?
and if i use a boost controller could i make more or less boost than the spring is set to?
is this the same for a hondata?
Old Jun 7, 2005 | 06:25 AM
Integra21's Avatar
Default Re: waste gate issue (CRXnorway)
to start off, the size wastegate is dependent on your set-up...
also i dont believe you can set the boost lower than the spring
Hondata is a good engine management
Old Jun 7, 2005 | 06:34 AM
ITRnorway's Avatar
well. i dont have money for a hondata setup now, so i`ll start with a boost controller and wideband and good gauges....
in a 300-350 hp setup, is a 38mm to smal?
Old Jun 7, 2005 | 06:48 AM
GaRn's Avatar
Default Re: (CRXnorway)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXnorway &raquo;</TD></TR><TR><TD CLASS="quote">well. i dont have money for a hondata setup now, so i`ll start with a boost controller and wideband and good gauges....
in a 300-350 hp setup, is a 38mm to smal?</TD></TR></TABLE>
well you will have the stuff to monitor, but what are you going to tune with???
Old Jun 7, 2005 | 07:04 AM
meltman1234's Avatar
Default Re: (GaRn)
Old Jun 7, 2005 | 07:08 AM
Drkaccrd's Avatar
Default Re: waste gate issue (Integra21)
No you cant set it lower. The lowest is the wastegate spring size. How much are you planning on boosting ?
Old Jun 7, 2005 | 09:00 AM
ITRnorway's Avatar
Default Re: waste gate issue (Drkaccrd)
well i have almost all the basic parts, but when i get enough money should i buy a sleeved shortblock. so when im waiting on that could i just drive getto style on my old motor. its real lame just to watch the turbo parts in a box at home and not under my hood so it will only be boosting 5psi on the stock engine..
i was wondering if the 38mm would e to small later
Old Jun 7, 2005 | 09:07 AM
How much psi do you think you are giong to run to hit your goal?
Old Jun 7, 2005 | 10:53 AM
Drkaccrd's Avatar
How much psi do you imagine your gonna run? Honestly, if you plan on running 15psi or even a little more just pistons and rods with a block guard should be fine. Get a good EMS and you should be straight .
Old Jun 9, 2005 | 06:54 AM
ITRnorway's Avatar
well, it would be about one bar, 15psi. but i want a setup that i can trust and drive every day. and what i have been told is block guard doing moore damage then good.
but would a 38mm tial be enough for 15psi?
Old Jun 10, 2005 | 05:25 AM
Drkaccrd's Avatar
Oh yeah no doubt. That wastegate is strong enough to hold 15psi and more ( cant remember how much ) as long as you dont cheap out a good fuel management system and build the motor with rods, pistons, block guard, a sleeved block is not be necessary.
Old Jun 10, 2005 | 12:52 PM
ITRnorway's Avatar
well, i think its better to invest in a sleeved block instead of going for a block guard
and hondata!!
but im not sure if i should just boost my current b16 when im waiting for a new block
Old Jun 10, 2005 | 02:20 PM
Drkaccrd's Avatar
Ok your choice. Why dont you ask other H-T members. A sleeved block, or built motor is just a waist of money if you dont invest in the proper fuel mangement. Especially if you plan on running 15psi or more. Noob mistake if you think a sleeved block is gonna save from blowing the motor. Ask anyone.........Your mistake man not mine.
Old Jun 10, 2005 | 02:50 PM
mike1114's Avatar
Drkaccrd is right. Most important thiing is good engine management and tune.
Forget the sleeve block thing, seriously. On a good tune, you can go up to around 450-500whp safely on stock sleeves. I'm pushing almost 350whp daily driven on stock sleeves forged rods/pistons.
U must bite the bullet and get good engine management. I know most people wanna skimp out on this part cause usually they save it for last, then don;t realize how ******* expensive it actually is. I know its hard with a box a parts staring at you but time and patience pay off.
Hondata, AEM EMS and I guess crome and uberdata are good. Motec if you got the $$
Old Jun 11, 2005 | 09:15 AM
ITRnorway's Avatar
yes! the built motor will be controlled by hondata.
my oem block dont get nothing so i dont care if im blowing that.... **** happends
boostedteg4dr
May 25, 2014 08:02 AM
DXK Eg
Jan 13, 2005 02:19 PM
Ls-Rturbo
Apr 20, 2004 05:43 PM
DubyaAye
Mar 12, 2004 12:50 PM
BlackThorN
Dec 21, 2003 12:51 AM
