Fluctuating boost?????
Old Jun 4, 2005 | 01:23 PM
OrangeBoost's Avatar
Default Fluctuating boost?????
Ok so I realise that small turbos will run out of breath but Ive got some funny stuff going on. Engine is a stock d16z6 w/ T3 .42/.48. WG actuator is 5psi but now I have a turbosmart MBC on it running 7psi.
Im building up to 7psi then around 4500rpm it drops down to about 3-3.5 psi. Once I get to about 5500 It goes back up to 5.5-6psi.
Whats going on???????? Why would it die so early then get a "second wind"?
Old Jun 5, 2005 | 11:49 AM
UP
Someone must be able to help[ me?
Old Jun 5, 2005 | 12:08 PM
Chris F's Avatar
Default Re: (OrangeBoost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OrangeBoost &raquo;</TD></TR><TR><TD CLASS="quote">Someone must be able to help[ me?</TD></TR></TABLE>
Pretty sure you have no boost leaks?
That is kinda weird, mine does a similar thing just as it hits VTEC, drops a pound or two for an instant.
Did it do this before you put the boost controller in?
Is the Turbosmart a vented type MBC? It could be opening too much too quickly, and then not recovering well.
Old Jun 5, 2005 | 05:17 PM
Im going to test things out again but IM quite certain it was holding a solid 5psi w/out the controller.
Im not sure what a vented boost controller is?????
Ok so lets assume that it holds a solid 5psi all the way to redline w/ out the controller...
WHy would the boost controller cause this to happen and what can I do to fix it?
racin jasin R
Jun 24, 2007 11:08 PM
lv6l
Sep 10, 2005 11:29 AM
ras
May 3, 2005 09:14 AM
Sam1am26
Nov 26, 2004 06:51 PM
