turbo tuning question
Old Jun 5, 2005 | 01:28 AM
crush's Avatar
Default turbo tuning question
before i tune my car with hondata do i need to get a 3 bar map or a missing link to tune it please lmk something thanks
Old Jun 5, 2005 | 01:36 AM
Quad-Damag's Avatar
Default Re: turbo tuning question (crush)
Hondata is a chiping for a almost standalone ecu, not really, but with hondata, you don't need a check valve or missing link, thats for a FMU
and you don't need a 3 bar sensor, unless you plan to run over 12 psi
stock map sensors can handel about 11.8 psi of boost, before they go crazy, the 3 bar makes it after 12 psi, the map doesn't go crazy
Old Jun 5, 2005 | 01:40 AM
crush's Avatar
i am going to run 16spi so i guess i would need one right
Old Jun 5, 2005 | 10:50 AM
scttydb411's Avatar
for only 16psi i'd recommend a motorolla 2.5bar mapsensor good for 22psi...you'll get better boosted map resolution.
Old Jun 5, 2005 | 12:16 PM
SOHC_MShue's Avatar
I would recommend the stock sensor for anything up to 13psi. You can just tune the last column slightly rich. After that you will need to upgrade though.
ganjasnack
Apr 18, 2008 06:08 AM
CaptainMorgan
Feb 13, 2004 01:35 PM
sneakypete
Jul 26, 2003 02:04 PM
Mr. Vapor
Sep 19, 2002 06:00 PM
The_Head
Jun 24, 2002 12:51 PM
