What and how should I check a used turbo to make sure it's in good shape?
Re: What and how should I check a used turbo to make sure it's in good shape? (USE2B16A)
Just grab the shaft and try to wiggle it up and down... Then in and out..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USE2B16A »</TD></TR><TR><TD CLASS="quote">That's easy enough, thanks. Anything else?</TD></TR></TABLE>
Any real testing needs to be done on a machine.. Also your going to have a little wobble since the bearings dont have any oil on them.. My Garrett turbo from the junkyard had a little bit of shaft play but when I fed oil into it, it didnt have any play at all..
Re: (Sinner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sinner »</TD></TR><TR><TD CLASS="quote">if its still attached to the car i'd check the intercooler for oil</TD></TR></TABLE>
There's no oil in the intercooler or the charge pipes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves »</TD></TR><TR><TD CLASS="quote">Any real testing needs to be done on a machine.. Also your going to have a little wobble since the bearings dont have any oil on them.. My Garrett turbo from the junkyard had a little bit of shaft play but when I fed oil into it, it didnt have any play at all..</TD></TR></TABLE>
Sounds good. Thanks guys.
TSPeed Factory
Re: (USE2B16A)
if its still in the car, drive it around for a bit and see if you can smell burning oil, or see oil coming out of the compressor inlet. thats a sign of a blown seal.
2000civic ex
07-10-2007 07:35 PM
