Greddy Turbo Timer Question
Old Jun 6, 2005 | 03:14 PM
Threads's Avatar
Default Greddy Turbo Timer Question
After my timer finishes counting down, it cuts the engine off, but when the timer turns off, it turns back on and powers the car. I have the 12V wired to the white ignition, the blue wired to the yellow igntion wire, and the green wired to the black/yellow ignition wire. My ground is spliced into one of my gauges grounds which is grounded with one of the engine grounds. I am pretty positive my wiring is correct and everything looks connected. Any help is appreciated.
Old Jun 6, 2005 | 05:09 PM
PrettyLude's Avatar
Default Re: Greddy Turbo Timer Question (Threads)
lets see
turbo timer--------------------your car
red white 12 volts
blue white black accessory
green black and yellow
black ground
seems like you have the wiring right did you hook up the e brake? that might be why its doing it
Old Jun 6, 2005 | 05:23 PM
Threads's Avatar
Default Re: Greddy Turbo Timer Question (PrettyLude)
The e-brake WAS wired, but came lose. I hear that you do not have to wire the e-brake in order for it to work. Also, I don't see what the e-brake would have to do with it not shutting off.
Old Jun 6, 2005 | 05:28 PM
PrettyLude's Avatar
if you have everything wired up correctly its the turbo timer itself, i used to have one, wouldn't work all the time, just when it wanted to, switched to the hks type 1 and no problem ever again, do a search for the greddy tt, you will read lots of posts that have the same problem as you
Old Jun 6, 2005 | 05:30 PM
Threads's Avatar
Default Re: (PrettyLude)
I searched under Greddy Turbo Timer and only found 1 post with my exact problem, and I believe it didn't have any response.
Old Jun 6, 2005 | 05:36 PM
PrettyLude's Avatar
did u check in the archives?
Old Jun 6, 2005 | 05:40 PM
Threads's Avatar
Yes, of course. Maybe you can find something i didn't see.
Old Jun 6, 2005 | 05:59 PM
PrettyLude's Avatar
https://honda-tech.com/zerothread?id=1192972
https://honda-tech.com/zerothread?id=1188945
Old Jun 7, 2005 | 11:43 AM
Threads's Avatar
Thanks for your help.
Just one more quick question:
If I turn my car off and leave the key in the ignition, the timer will count-down and cut off, but as soon as i take the key out, it will turn back on. Does this narrow down anything on what might it could be?
Old Jun 7, 2005 | 04:13 PM
Threads's Avatar
Default Re: (Threads)
Any more input?
ham
May 5, 2005 04:22 PM
mooook
Dec 31, 2004 12:26 PM
pip9
May 29, 2004 08:33 AM
Superorb
May 27, 2004 03:21 PM
Infinity_Racer
Apr 2, 2003 05:52 PM
