OIL FEED
Old Jun 4, 2005 | 02:41 PM
Pure Sol's Avatar
Default OIL FEED
i have a slight problem that i need help with, i have a banjo bolt with the oil feed line that the turbo kit came with, i bought the greddy oil filter adapter which has a 12 X 1.25 bolt hole. the problem is the supplied banjo bolt does not have the same threads as the greddy adapter. i need a M12 X 1.25 banjo bolt but have had no luck with the local part stores. any help is appreciated. Thanx
Old Jun 4, 2005 | 03:33 PM
EnzoSpeed's Avatar
Default Re: OIL FEED (Pure Sol)
Can't you just keep the bolt you have and use an adapter to connect it to the oil sandwich?
BTW, I like your avatar. I remember back in high school I would try to turn in papers printed with that same font, lol. IIRC, it's called "Group Sex"...
Old Jun 4, 2005 | 06:01 PM
Pure Sol's Avatar
Default Re: OIL FEED (EnzoSpeed)
no its just got the bolt for the oil feed and then the oil in the oil adapter. its just like a thread off so im guessing its probably 1.50 in the adapter
Old Jun 4, 2005 | 06:37 PM
hybridsol's Avatar
You won't find a bolt like that at any local store. Try Summit racing.
http://www.summitracing.com/
You may need to call them to explain what you need. They are very helpful.
Old Jun 4, 2005 | 06:53 PM
Crasian's Avatar
why not get a die and re thread the current bolt u have, i dunno, its just an idea, mite save u some money
Old Jun 4, 2005 | 08:59 PM
Pure Sol's Avatar
Default Re: (FarOutCoupe)
ill try summit racing before i do anything else but i thought that one out too, but got concerned with it leaking. But now that i think it over if its only a thread off it shouldn't be that big of a deal to re-thread it right?
boostmee
Aug 18, 2008 02:05 PM
1991civicd16z6
Jun 8, 2008 11:35 AM
SdGSR01
Apr 2, 2005 01:50 PM
eg crunkmonster
Feb 3, 2004 08:47 PM
VTgringo
Jun 30, 2003 07:36 PM
