WASTEGATE HELP!
Old Jun 7, 2005 | 05:06 PM
crxzcracer's Avatar
From: Murfreesboro, Tennessee, United States of America
Default WASTEGATE HELP!
My wastegate will not open. it blows air out of the top hole with it should not do (right?) so i took it apart and it all looked find no hole in the diaphram. so what do yall think?
pls. help
if you look at this pls. bump
Old Jun 7, 2005 | 05:44 PM
kasso's Avatar
what kind of wg is it?
Old Jun 7, 2005 | 05:45 PM
crxzcracer's Avatar
Default Re: (kasso)
http://www.xs-power.com/turbo-...i.htm
Old Jun 8, 2005 | 06:34 PM
integlspwr2k's Avatar
Default Re: (crxzcracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxzcracer &raquo;</TD></TR><TR><TD CLASS="quote">http://www.xs-power.com/turbo-...i.htm</TD></TR></TABLE>
Old Jun 9, 2005 | 06:28 AM
crxzcracer's Avatar
Default Re: (integlspwr2k)
well dosent help me to much but thanks
Old Jun 12, 2005 | 09:33 PM
kasso's Avatar
bump. i would like to know also
Old Jun 12, 2005 | 10:30 PM
Endoe's Avatar
Default Re: WASTEGATE HELP! (crxzcracer)
have you mess with your springs? double check everything from vaccum to bolts...sorry never had that problem...
Old Jun 13, 2005 | 06:02 AM
crxzcracer's Avatar
Default Re: WASTEGATE HELP! (Endoe)
I took all the vacum lines off and check them and the bolts on the wastegate.
i didnt do any thing to the wastegate i just took it off set it on the floorboard, replaced the headgasket and put it back on and now it wont open
Old Jun 13, 2005 | 07:05 AM
ginoboy1978's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlspwr2k &raquo;</TD></TR><TR><TD CLASS="quote">
It's a good wastegate....xs-power, tial, etc.....they are all the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxzcracer &raquo;</TD></TR><TR><TD CLASS="quote">My wastegate will not open. it blows air out of the top hole with it should not do (right?) so i took it apart and it all looked find no hole in the diaphram. so what do yall think?
pls. help
if you look at this pls. bump</TD></TR></TABLE>
Regarding your problem, if it's not opening your getting alot of boost then? I never heard of air blowing out of the top hole.
DAN
Old Jun 13, 2005 | 09:04 AM
bigapple427's Avatar
Default Re: (ginoboy1978)
i like mine but i themhad to put longer bolts in around the outside kept losing
Old Jun 13, 2005 | 09:27 AM
dustin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ginoboy1978 &raquo;</TD></TR><TR><TD CLASS="quote">
Uh huh
Old Jun 13, 2005 | 02:59 PM
crxzcracer's Avatar
Default Re: (dustin)
if there was a hole in the diaphram would it make air come out the top?
Old Jun 13, 2005 | 03:05 PM
dustin's Avatar
Yes. But there doesn't have to be a hole for air to come out... the edge of the diaphram could not be sealing. it could be damaged or not installed correctly. If you have taken the wastegate apart, be careful when re-assembling it. It is easy to pinch the diaphram.
Old Jun 13, 2005 | 03:28 PM
crxzcracer's Avatar
i had never taken it apart before this happen tho
Old Jun 13, 2005 | 03:31 PM
dustin's Avatar
Also note that if air is actually coming out of the wastegate, you have a vacuum leak.
Can you push the plunger in on the wastegate? maybe it is seized internally. I mean, you are working with a chinese made knockoff wastegate here.
Old Jun 13, 2005 | 03:34 PM
crxzcracer's Avatar
yes i can push it in
Old Jun 13, 2005 | 03:38 PM
crxzcracer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">Also note that if air is actually coming out of the wastegate, you have a vacuum leak.</TD></TR></TABLE>
but if i take the waste gate off the car and blow in the hole on the side as boost would it just blows out of the top, it souldnt blow out the top unless it hit the pressure at which the wastegate sould open then the extra air would blow out the top
Old Jun 13, 2005 | 05:00 PM
dustin's Avatar
Ok, first, nothing should ever come out of the top port of the wastegate. It's sealed. If you are blowing in the side port and it comes out the top port, there is a huge leak inside the wastegate.
Second, the wastegate does not bleed off "extra air" out the top. The wastegate is a bypass before the turbo, re-routing exhaust gas past the turbine wheel. This prevents the turbo from making additional boost. It does not bleed off boost.
crazy_ls_90
Oct 2, 2008 05:28 PM
2SLO
Aug 28, 2008 07:18 AM
Wilky
Nov 3, 2006 05:51 AM
1badda
Sep 28, 2006 06:24 AM
boostsohfast
Feb 4, 2004 12:57 PM
