to turbo or not to turbo?
I have a stock 94 CX and a friend of mine has a small turbo (mazda 626) and i was thinkin about putin together a ghetto turbo. would the d15b8 be able to hold boost as a daily driver. it would never exceed 6psi, in fact that is a maximum i would run. just curious if u think the engine would hold up.
Re: to turbo or not to turbo? (Mik3)
unknown because of a guage cluster swap, but it doesnt burn oil and seems mosly sound. pedals dont have much wear so i doubt the milage is too high.
Re: to turbo or not to turbo? (PhoenixTurboEric)
everyone says that they will only boost 5 or 6 psi...i said it to...then the first thing they buy after install is a boost controller...if you treat it good and dont up the boost like crazy you should be good...but youll be tempted.
Re: to turbo or not to turbo? (hotimportcrx)
First: Do a compression test and report back
Second: Do a leak down test if you feel that you leak coolant, oil, or blow smoke anywhere
Third: If those 2 check out boost away on a good tune and proper maitenance and you'll be fine
Re: to turbo or not to turbo? (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy »</TD></TR><TR><TD CLASS="quote">First: Do a compression test and report back
Third: If those 2 check out boost away on a good tune and proper maitenance and you'll be fine </TD></TR></TABLE>
Which one will be more dangerous for stock internals? small turbo high psi / big turbo low psi? or h
elpiar
08-04-2005 01:52 PM
