ELECTRICAL problem.... and tach tooo HELP>> PLEASE
Old Jun 7, 2005 | 07:22 PM
ATgrills.com's Avatar
Default ELECTRICAL problem.... and tach tooo HELP>> PLEASE
Well i finally got arrount to trying to fix my weird tach problem,, It use to go up and down at 4500RPM..... just basically go all over the place as soon as I would go over 4500RPM>..
so I was told to Wire it straight to my MSD ignition box where there is a signal output on the side,,, I wired it directly into the back of my cluster so its a direct line.... it seemed to work perfect in neutral
then I went for a rip and as soon as I hit fullboost and about 7000RPM it does the same thing and goes all messed up... my redline is 8750RPM so its very frustrating cuz i dont know when to shift...
NOW should I rewire the tach directly to the distributor?? would that work???
SECOND PROBLEM.... MY AUTOMETER PYRO GAUGE
I had the power souce hooked up the power on the back of my radio...and If I played it loud ( i have a sub) the pyro gauage would flick all over the place... as soon as I would turn down the radio it would go away...
-So i figured the logical explanation was that the radio was draining volts when the bass would hit...
SO i wired it directly to the fuse box in the engine bay,,, and I still have the same problem...... any suggestions??
PLEASE HELP!
Tyler
Old Jun 7, 2005 | 08:17 PM
PrettyLude's Avatar
if ur tach is bouncing all over the place after 4500, i bet ur ignitor is on its way out
Old Jun 7, 2005 | 08:21 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (PrettyLude)
My buddies EGT does the same thing every once in a while, Ive herd cause its a bad ground but I couldnt really tell ya. As for the tach taking a dump on you, I second the ignitor is going out...
Blaze
Old Jun 8, 2005 | 03:45 AM
Default Re: (Blaze45)
I dont have an ignitor,, i have a external MSD coil and Ignition system!
duck22krazy
Dec 13, 2008 05:18 PM
Integra21
Dec 26, 2006 08:39 PM
ATgrills.com
Jun 8, 2005 07:08 PM
