basemap question
Old Jan 9, 2013 | 06:10 PM
hybridmiklo's Avatar
Default basemap question
I currently have hondata s300 that was tuned on my d15b vtec turbo setup. I pulled the motor and now have a b20vtec that I am about to turbo using the same turbo and same injectors. My question is can I use the hondata map on my current setup to get around? It will not go above 3500rpm. Can i do this safely while waiting to go to the dyno?
Old Jan 9, 2013 | 06:17 PM
Turbo-LS's Avatar
Default Re: basemap question
If you have a wideband in the car and do not boost it, but it will still need fuel added to run correctly
Old Jan 9, 2013 | 07:16 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
Co-sign
Different motors have different properties
Old Jan 9, 2013 | 07:19 PM
turbohatch96y7's Avatar
If you have an s300 and the usb cable, richen up the map at the Very least and keep an eye on th a\f ratio better to have it rich than lean.
Old Jan 10, 2013 | 11:23 AM
so the map would not run safely under 3500rpms?
Old Jan 10, 2013 | 11:52 AM
wantboost's Avatar
Who is Mr Robot?
Both engines have different fueling requirements, all you can do is toss it in and see how it works
hastingsr
Aug 23, 2008 08:22 AM
88crxhfb16
Aug 3, 2005 01:57 PM
irocdaparty85
Jul 25, 2005 09:23 AM
*Boostwerks*
Jan 13, 2004 10:39 AM
TurBoTeG
Jul 6, 2002 12:30 PM
