ls vtec turbo lose power in 4rth gear
my car is losing power when i shift to 4 gear but is for 1 second then
start to spin the tires again. It's like a instant drop of power, she is tuned and
nothing was touch. Maybe my intercooler is to small 28x7x2.5? The clutch is not sliping.
383whp@17psi
sc34
9.0:1 srp
gsr cams
650cc inj
28x7x2.5 ebay ???
383whp@17psi
sc34
9.0:1 srp
gsr cams
650cc inj
28x7x2.5 ebay ???
Re: ls vtec turbo lose power in 4rth gear
Same thing happend to me today
I had a clamp loose on the charge pipe
Would build boost fine and hold it
Drop when I shifted and then build slowly for a second and then fast again
Check all the clamps out
reajust all the t-bolts and check the couplings all loock fine. Can't check the
car cause it's raining so heavy.
hi guys, been a wile since the problem start but work and D.D. car issues have me busy.
the car still running strong the firts 3 gears but whit the same problem when
shift to 4th a little fall in power for a second and then hit again.
no boost leaks.
no boost leaks.
Greg1995Civic
10-23-2014 07:54 AM
Fired Honda
06-26-2003 08:43 PM
