After thé pump GAS?
Old Dec 30, 2012 | 03:53 PM
Steeve_Civic's Avatar
Default After thé pump GAS?
Past 20 PSI I think it is Time to change the pump GAS even if you can find some 93 octane.
Should I add methanol? Or E85fuel?
Do you add methanol with C16 fuel?
Old Dec 30, 2012 | 04:30 PM
TheShodan's Avatar
Moderator
Default Re: After thé pump GAS?
Its up to what's available in your area. don't add ANYTHING to c16. BAD IDEA.
Choose what you want based upon your purpose and availability of that fuel.. That's a question we can't answer.
Old Dec 30, 2012 | 04:59 PM
ekcoupeh22's Avatar
Yeah run c16 independently...I don't like meth cause it runs out and that's just another system to fail...I love e85 but more than likely you'll have to upgrade the fuel system bc it requires 30% more fuel
Old Dec 30, 2012 | 07:34 PM
duf2570's Avatar
or just do a map for racefuel(dragdays)and stay at 20 psi on the 93 octane for daily drive??i agree that meth is just more thing that can fail but a good way to prevent it its going in the right way when assembling and look everyday the ''réservoir''..so im going on my fourth year on meth and (cross fingers)no issue...
if 93 octane over is disponible go with it like theshodan said
Old Dec 30, 2012 | 07:35 PM
TheShodan's Avatar
Moderator
Absolutely. We have warning indicators on the Aquamist. Plus under a certain level it won't allow higher boost pressures when the ecu is working with it, like the AEM.
Old Jan 2, 2013 | 01:05 AM
OK, thank you for your Meth returns.
As far as it is for DRAG racing, I will stay for street with 20 PSI and 93 octane (pump gas) and C16fuel for race.
The problem is that I need to empty the OEM Fuel tank to the fill with C16 if I want to make a C16 fuel map.
Old Jan 2, 2013 | 01:06 AM
What is the problem with AEM and Meth?
Old Jan 2, 2013 | 04:17 AM
TheShodan's Avatar
Moderator
Nothing is wrong. When doing a race map, emptying the tank is just part of the job. We all do that when doing a c16 map
Old Jan 2, 2013 | 04:42 AM
EddieCRX's Avatar
Steve
I live just outside Paris (Sucy En Brie), would be good to see your car some time.
Old Jan 2, 2013 | 12:42 PM
Yes if you want, dude !
I live in the 91, south Paris
portenio78
Nov 21, 2010 01:47 PM
boostincoupe
Dec 13, 2007 09:20 AM
Motorgroove
Jun 14, 2004 08:14 AM
migo
Aug 12, 2001 12:12 PM
