blown head gasket?
Old Jan 26, 2013 | 06:06 PM
heyitzspikey's Avatar
Default blown head gasket?
Hello I just bought a car from someone that said the motor was fully built the car is not tune. Me being dumb I drove it to make sure it doesnt die out or overheat. It was fine so I bought it the next day I was changing my oil I notice the oil was milky... so I changed the oil and did a compression test number was 40, 60, 70, 80 acceoss the board. But the motor idle fine and sound fine....
Old Jan 26, 2013 | 06:08 PM
Default Re: blown head gasket?
89 crx Darton sleeve 84mm bore eagle rod wiseco piston 8.5.1 compress itr oil pump arp main and head bolt gsr grutle itr head with super tech valves train Victor x manifold 880 cc persicion. 255 walbro am cam gear 7 lb fly wheel turbonectic wastegate garret turbo log manifold
Old Jan 26, 2013 | 06:09 PM
Turbo-LS's Avatar
its not fine do not run it anymore blow headgasket and hopefully not ruined piston rings
Old Jan 26, 2013 | 06:18 PM
So you think its the head gasket? If so I will run to autozone and rent the tester for the head gasket checker
Old Jan 26, 2013 | 06:56 PM
Turbo-LS's Avatar
theres nothing to test if your oil is milky then its blown
Old Jan 26, 2013 | 07:27 PM
SiRCiviC94's Avatar
Replace gasket replace oil do an oil flush
Old Jan 26, 2013 | 07:33 PM
phaphon's Avatar
you also might want to double check if the autozone hg will work. correct me if im wrong, but a b20 hg wont work on a 84mm gsr block
Old Jan 26, 2013 | 07:56 PM
I will just order the golden eagle brand
Old Jan 26, 2013 | 09:17 PM
my motor is idling fine and not over heating when park but what I dont understand is would I hear are notice anything wrong if compression test number was 40, 60, 70, 80?
Old Jan 26, 2013 | 09:18 PM
I called the guy I bought the motor from and he said it never over heated on him, he said the car sat for 2 month only before he sold it too me but that doest explain the very very low compression test it doest make sense
Old Jan 27, 2013 | 03:03 AM
grumblemarc's Avatar
The Grumpiest
Healthy MINIMUM compression numbers are 135psi. Your numbers are beyond past bad at this point or you messed up the compression test badly. A blown headgasket doesn't necessarily have to cause the engine to overheat either. Keep driving it like that and you'll be sorry. Change the damn headgasket.
Old Jan 27, 2013 | 07:04 AM
SiRCiviC94's Avatar
Hahahaha guy selling was so stoked you didn't pull out any test equipment and baught cause it ran :p
Old Jan 27, 2013 | 02:34 PM
just remove my head at least the guy was right about the block is being built...
will finish puting the new gasket on next sat hopefully it will bring the compression back up. What is a good compression for 8.5:1?
Old Jan 27, 2013 | 02:57 PM
Does those look like Darton sleeve?
Old Jan 27, 2013 | 03:43 PM
turbohatch96y7's Avatar
Check the block and head with a flat edge, make sure the block or head isn't warped.
Old Jan 27, 2013 | 04:09 PM
How do I know if the sleeve are sunking?
Old Jan 27, 2013 | 04:15 PM
The Grumpiest
They would be sinking.
Old Jan 27, 2013 | 04:21 PM
I know that.... the sleeves are lower then the block how will I check it?
Old Jan 27, 2013 | 04:32 PM
mafia's Avatar
Precision straight edge and feeler gauge.
Old Jan 27, 2013 | 04:39 PM
so I do it from the block over the sleeve? if so the sleeve part is lower then the block already.
Old Jan 27, 2013 | 04:48 PM
mafia's Avatar
Just A thought, I wonder if you can get the block resurfaced to the sleeves (if in service limits)? If anything you need to find out how much lower the sleeves are, Im sure this is bad...
Old Jan 27, 2013 | 04:56 PM
Should it be flush or not?
Old Jan 27, 2013 | 05:30 PM
wantboost's Avatar
Who is Mr Robot?
Your spelling and grammar makes me want to beat retarded children...
Those are dart on sleeves, everything looks fine, clean all of that **** out of the cylinders and put the new gasket on already..... the questions you're asking we can't answer unless we can physically touch the damn motor
Install the damn gasket already and go from there
Old Jan 27, 2013 | 06:22 PM
hardcore97's Avatar
looks like GE sleeves to me.
Old Jan 27, 2013 | 07:04 PM
SiRCiviC94's Avatar
Clean it up nice with air and rags. I hope it works out for you. Nice block.
