darton sleeve help
Old Feb 6, 2013 | 10:00 PM
94civicgsr's Avatar
Default darton sleeve help
I am currently looking to buy a b18c and a shop started to put darton sleeves in and supposedly the machinist quit and they put two sleeves in and left the other two sleeves about an inch up. can any one give me any advise on what to do. i would like to use golden eagle but not sure if they can remove what there and install theirs or do i need to find a reputable shop to try to figure out what the last shop never finished.
Old Feb 6, 2013 | 10:15 PM
Mach1n1st's Avatar
Default Re: darton sleeve help
Are they mid sleeves or dry liners??
Old Feb 8, 2013 | 02:28 PM
94civicgsr's Avatar
the guy told me they are dry liners but he is supposed to send me pictures.
Old Feb 8, 2013 | 04:15 PM
wantboost's Avatar
Who is Mr Robot?
Dry liners aren't really worth it, because the liner is still being supported by the stock aluminum casting, which is where the weak link is.
For a sleeve to be strong it needs to replace the entire stock casting, like the MID sleeves.
Old Feb 8, 2013 | 04:54 PM
94civicgsr's Avatar
here is a picture that he sent me
Old Feb 8, 2013 | 05:01 PM
wantboost's Avatar
Who is Mr Robot?
Those are mid's
Old Feb 8, 2013 | 05:08 PM
94civicgsr's Avatar
thats what i thought after getting the picture but my question is can i still finish having them installed cause im not sure if it is ok to leave two not pressed in and tork plated for so long
Old Feb 8, 2013 | 05:42 PM
wantboost's Avatar
Who is Mr Robot?
They would have to be pressed in.... there's no other way to do it
Old Feb 10, 2013 | 08:56 PM
Steve D's Avatar
From your photo, it doesn't look like the sleeves are correctly aligned for installation.
The only way to do this to make certain you won't have issues is to remove all the sleeves, inspect the work and assuming the machine work was correctly done, reinstall the sleeves with new o rings and the proper grades of Loctite and then deck it.
If you want to send the block in to Darton I'll check it out for you and see what the deal is.
Kind of strange one would quit right in the middle of a sleeve installation.
Steve
Old Feb 11, 2013 | 01:09 AM
wantboost's Avatar
Who is Mr Robot?
Yea, I don't see why they pressed two in then stopped, very weird, unless there was a problem with the ,machine work and the last two sleeves cannot be installed
And you'll have on hell of a time trying to get the two installed sleeves out of the block... the loctite used to seal them is stupid strong... you'll need a serious heat source and a pretty big press, as well as some creativity.
Old Feb 11, 2013 | 02:58 AM
mar778c's Avatar
Community Builder
Community Influencer
This is the worst I've seen in a while. Call justice race engines. They have considerable experience with engine sleeving.
Old Feb 11, 2013 | 07:45 PM
94civicgsr's Avatar
Steve
Steve thank you for seeing my post. I have no idea what happened to the machinist i picked this motor up and starting to worry me can you pm me a average price for you to look at my problem and try to fix.
cvelazquez
Jun 17, 2014 12:36 PM
mustanggtandgsxr
Apr 3, 2008 09:46 PM
blakh
Jan 24, 2008 09:14 PM
KeyserSoze
May 14, 2005 09:40 AM
EEK
Aug 9, 2002 09:59 AM
