b16a2 help
Old Feb 9, 2013 | 06:42 PM
LowNSlow6's Avatar
Icon2 b16a2 help
i have an b16a2 it has a turbo setup on it 8 psi the car ran good until i put dsm 450 injectors and walbro 255 fuel pump tdy i set my fuel regulator to 40psi i conencted the resonator box also
so the cars acting really wierd it sounds like its not firing on all cylinders it takes a while for it to jump to normal rpms the engines shaking and when it gets to the good rpms i took it for a spin couple times n its cutting out at 6k rpms or when ur just cruising low rpms 3-4 rpms it feels like u would just slam on the brakes not a fun ride anymore
i need help i tried allot of **** tdy n nothing ...put the stock injectors or what u guys think ?
changed the spark plugs distributor cap and rotor wires r good cuz i replaced them not too long ago
get a tune ?
Old Feb 9, 2013 | 08:34 PM
eghatch9295's Avatar
Stancetard Hate Monger
Default Re: b16a2 help
jesus. tapdancing. christ. please stop working on your own car. why do people think they can slap random **** for a turbo kit on their car and run well? i gots this hobknob assfuck concoction of parts and it aint runnin rite!!!!11!!! GET A GODDAMNED TUNE!
Old Feb 9, 2013 | 10:35 PM
jbpnoman's Avatar
You can't just swap injectors without a professional tune. Injectors run on pulse times. They stay open for a defined fraction of a second to allow a metered amount of fuel into the cylinder. When you change from the stock (240CC) injectors to those 450CC injectors, you're DOUBLING the amount of fuel your engine gets.
tl;dr - you're flooding the engine. You should learn what the parts of your car do and how they work before you go grenading your motor.
Old Feb 10, 2013 | 04:17 PM
LowNSlow6's Avatar
ok relax mister perfect if u dont knw the answer then dont post at alll perent didnt teach u ? sorry to hear
Last edited by Former User; Feb 10, 2013 at 04:40 PM. Reason: post clean up - keep the discussion civil
Old Feb 10, 2013 | 04:19 PM
doood's Avatar
been there done that
he did answer your question
Last edited by Former User; Feb 10, 2013 at 04:40 PM. Reason: Thread clean up for OP's remarks
LowNSlow6's Avatar
thanks alot for ur help i got the problem fixed it wasent the tune my sping inside the wastegate broke n thats y it did that
Old Feb 10, 2013 | 04:20 PM
LowNSlow6's Avatar
no he didnt cuz it wasent the tune
Old Feb 10, 2013 | 04:42 PM
doood's Avatar
right. because bigger injectors will run right on a tune for smaller ones. got it.
Old Feb 10, 2013 | 05:11 PM
grumblemarc's Avatar
The Grumpiest
A broken wastegate spring will make the car run like it's not firing on all cylinders?
Old Feb 10, 2013 | 05:37 PM
wantboost's Avatar
Who is Mr Robot?
The gene pool, please leave it as soon as possible.
God forbid you breed... your kids would amount to cannon fodder... although the world still needs ditch diggers.
And there's no way you change injectors and have the car run right without a tune... you're an idiot
Old Feb 10, 2013 | 06:04 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
OP
You need a retune with bigger injectors, it's common knowledge
FormerDSMguy
Mar 17, 2017 06:47 AM
Devious951
Aug 15, 2009 02:23 PM
blackccoupe
Apr 17, 2007 01:37 AM
_HANS
Jun 12, 2004 08:53 AM
