Moroso Oil pan capacity question?
The Grumpiest
Re: Moroso Oil pan capacity question?
Google.
Key Features:
Wet sump, 5.5 oil quart capacity (not including oil filter capacity), 6" deep
Compatible with all B-series VTEC & non-VTEC engines (B16-B18-B20)
Works with OEM exhaust manifold and most aftermarket exhaust/header combination's
Kicked out sump that increases oil capacity to 5.5 quarts
Includes 6 trap doors, 2 baffles, and removable sump tray that keeps oil contained in the pickup area during hard acceleration, cornering and braking.
Turbo/Supercharger oil drainback
Features a magnetic drainplug and temperature sensor bung provision
Clear zinc plating for durability and corrosion resistance
Uses stock OEM Honda oil pan gasket
Key Features:
is you dipstick tube installed all the way like stock? my gsr block i couldnt get it all the way down so i had to adjust where on the stick was full
