D15b7/a6 turbo help!
Old Jan 1, 2013 | 04:44 AM
That_honda_guy's Avatar
Default D15b7/a6 turbo help!
Hey honda tech , so i have a 1992 honda civic hatch , this is my set up = d15b7 block stock with d16a6 si head stock , i have a emusa manifold running a bullseye 57 trim turbo on 10 pounds , i have stock fuel rail and lines but iam running rc 310 injectors and running 255lph fuel pump , iam running stock map with a missing link , recently (1week ago) i was running 8 psi on this set up and it was running like a champ , afr was 13.1 under 8 psi , i was like this untuned and it was a daily driver constent abuse , 1200miles in a month in town driveing , now iam on 10 pounds same set up no changes , now it has alot of hesitation under wot(10 psi at 3600) and wont go , but under part throtle it goes like a bat out of hell .. Any help pleaseee!!!!
Old Jan 1, 2013 | 05:37 AM
kenneek9's Avatar
Default Re: D15b7/a6 turbo help!
gday there
sorry to say this, but i'll make it short and sweet
GET A REAL EMS and GET A GOOD TUNE
that will save you money, and save that motor of yours (plus alot of headaches and forum surfing)
Old Jan 1, 2013 | 09:54 AM
Aradin's Avatar
Premium Member
Stop beating on that car or you're going to blow it up. 13.1 AFR in boost is way too lean. Should be 11.5-11.8 to be safe. Get a tune before you grenade that motor.
Old Jan 1, 2013 | 10:21 AM
Hidenplanvew's Avatar
You need to get it tuned... d15 stock blocks are only good for like 180whp sooo... Im sure you are leaning out 310 injectors are only good to like 220hp
Old Jan 1, 2013 | 10:23 AM
I have a old style hondata ecu that i wanna run but no one in town can tune it , so iam not sure what to do! .. And is there truthfulyy anyway to reach it out more? Posibly running pr4 ecu? Or should i invest in fuel rail and regulator tell i can afford a tuner .. Thanks for yalls help and being truth full .. I have a b18c 98+ spec just sitting here waiting for this motor to give .. But iam trying to sqweez couple more months outa this motor
Old Jan 1, 2013 | 08:38 PM
Well Hondata does have a trade in program.. A pr4 will do nothing for you, diffrent maping of fuel and timming. I would just get a new hondata and tune, no need to break down far from home.
R3X5150
Aug 28, 2013 05:23 PM
hotimportcrx
Oct 2, 2005 04:13 PM
crazychrisjdmcrx
May 17, 2005 08:12 AM
civic dx
Oct 1, 2003 05:19 PM
AlphaKennyWun
Dec 22, 2001 08:27 AM
