Hx55 comp. map?
Old Jan 6, 2013 | 04:45 PM
Loudk's Avatar
Default Hx55 comp. map?
Anyone have a compressor map for a holset hx55. I have already figured my data for lb/min and pressure ratio. Holset seems to be holding out on the comp maps. Someone HELP!!!!!
Old Jan 6, 2013 | 06:41 PM
Loudk's Avatar
Default Re: Hx55 comp. map?
From what I understand .46 kgs is ~60lb/min
Either way I need to know the hx55 low, high, and optimal ratings at ~2.5-2.8 pressure rating.
Old Jan 6, 2013 | 06:43 PM
Loudk's Avatar
That's the ghetto map that holset puts out. So secretive
Old Jan 6, 2013 | 06:55 PM
TheShodan's Avatar
Moderator
They aren't secretive, just didn't want to put on the internet all day long. Its there, its a matter of finding a good part of the Cummins Turbo Technologies.
This is reagrding the Holset HX55 B98 series turbo
No. not even close. These are about 72lbs/min at 2.9PR at maximum speed 110,000rpms at about 68% efficiency
2.5PR = 38lbs/min at about 80,000rpms -- This is the sweet spot at 78% efficiency
2.8PR = 58lbs/min at about 90,000rpms -- Another good sweet spot at about 76% efficiency
I have access to some of the Cummins Turbo database as a consultant. They will not allow us to copy a PDF of sectioned maps. Actually, its very confusing going through even the site.
Old Jan 6, 2013 | 08:19 PM
wantboost's Avatar
Who is Mr Robot?
Print screen
Old Jan 6, 2013 | 08:24 PM
TheShodan's Avatar
Moderator
I'll just Get a scanned image from my master book this week.
Old Jan 6, 2013 | 09:03 PM
Loudk's Avatar
I'll be right at 2.5, thank you. I needed to confirm my pr was good. As to what I said earlier I think you misunderstood. I said .46kgs is ~60 lb/min. I.e. a reference of kgs vs. lb/min. But thank you for the very useful info. I'll be at 2.5 pr from ~5700-8700
Old Jan 7, 2013 | 06:46 AM
TheShodan's Avatar
Moderator
Hope I was helpful.. Good luck!!
Old Jan 7, 2013 | 07:44 AM
Loudk's Avatar
Very much so thankmyou
Old Jan 7, 2013 | 07:53 AM
92cxyd's Avatar
Old Jan 7, 2013 | 10:52 AM
Loudk's Avatar
^ cool but worthless to me without values. I need to see pr and lb/min
Old Jan 7, 2013 | 10:58 AM
92cxyd's Avatar
Ok try this:
Old Jan 7, 2013 | 12:28 PM
TheShodan's Avatar
Moderator
That's about right...
Old Jan 7, 2013 | 03:14 PM
Loudk's Avatar
Instant gratification
Old Jan 7, 2013 | 03:53 PM
Loudk's Avatar
codenamezero
Dec 24, 2011 08:24 PM
b18bEKcoupe
Apr 12, 2005 07:27 PM
Teh_Oven
Feb 5, 2004 11:30 AM
