checking used block internals? pic
Old Jan 4, 2013 | 09:35 PM
SiRCiviC94's Avatar
Default checking used block internals? pic
There is a local "turbo block" for sale the seller is unsure of its specs and id like to go over there and eye it out. I know its a 1.6 block, basically I want to know how easily i can ID the pistons and rods and check if its good?
my plan so far is to bring a venier to measure the bore, and something so i can spin the rotating assembly with some oil of coarse. then if the seller will allow it take the pan off and check the internals.
how much is not low balling for a built block? its a bit sketch lol
pic
Old Jan 4, 2013 | 09:52 PM
Spawne32's Avatar
Default Re: checking used block internals? pic
The pistons are cast, i can tell you that right now just by looking at the tops, typically the oem pistons will have the code stamped onto the top of the piston. It's hard to say that this block is sleeved or not, typically sleeved blocks will have some sort of guard depending on which sleeves are used in the water jacket itself. Although replacement sleeves like ones I have seen from RSmachines and LAsleeves can be open deck with no reinforcement.
Typically on OEM sleeves there is a clear distinction between the cast iron liner and the aluminum outer sleeve.
not sure you will be able to determine what brand connecting rods are on it, but if you dont see anything thicker that your typical OEM rod, then it probably isnt an aftermarket rod. The cheapest connecting rods out there are very thick H beams.
Take a look at the rod bolts holding the rod onto the crank, they will typically be 12 point if they have been upgraded.
Old Jan 4, 2013 | 09:53 PM
Spawne32's Avatar
i will say that the rest of that block looks horrific, like its been sitting in salt water for years, even the coolant pipe and every other part on it looks pretty bad.
Old Jan 4, 2013 | 10:53 PM
rich7777's Avatar
It looks like the seller has cleaned it up with a wire brush to me..
Old Jan 4, 2013 | 11:04 PM
Spawne32's Avatar
lol i didnt want to say that yet until i had some better pics :p
Old Jan 4, 2013 | 11:12 PM
rich7777's Avatar
Haha, I wouldn't buy it. It has "there is something wrong with me that I'm trying to hide" wrote all over it.
If something's to cheap to be true; then it most likely is...
Old Jan 5, 2013 | 06:11 AM
SiRCiviC94's Avatar
i was thinking theyre a cast piston as well thats not so great...I guess theres no way at all to get the compression ratio? good point on the rod bolts ill be for sure getting in there and taking pics. the seller has full itr swap y7 swap, gsr intake and tb....lots of stuff sitting for some reason. the pic it doesnt look sleeved.
my other concern is the block was pulled cause of a bearing problem which could go un noticed to a buyer.
Old Jan 5, 2013 | 06:18 AM
SiRCiviC94's Avatar
another pic
Old Jan 5, 2013 | 06:27 AM
rich7777's Avatar
Don't buy it man. You will just be buying someone else's problem. Build you're own block... and do it properly.
Old Jan 5, 2013 | 06:46 AM
SiRCiviC94's Avatar
roger that. i dont have the supporting mods to make over 350 anyway but id love to have a turbo engine on a stand ready to go I still start my b18c every day n think fkkkk i should be boosting this motor and not my tired b16a lol
Old Jan 5, 2013 | 09:51 AM
ekcoupeh22's Avatar
that looks like a stock motor nothing else...just becuse someobody put a turbo on it doesnt make it a built motor
Old Jan 5, 2013 | 01:39 PM
SiRCiviC94's Avatar
^ good eye i shoulda caught that too. the seller had no idea what it was....it was turboed ""
its a stock b16a block lol!!!! how'd it run so clean though those pistons look fresh as hell unless a leaned out tune would clean them up.
Till next time boys
Old Jan 5, 2013 | 01:42 PM
ekcoupeh22's Avatar
A can of brake cleaner and a red scuff pads make everything look brand new lol
GT500FTW
Nov 3, 2014 02:32 PM
b16lewis
Oct 1, 2014 05:48 PM
trigger_time
Nov 2, 2010 10:03 AM
lsvtecturbosol
May 23, 2009 02:07 PM
BoostedSi
May 18, 2002 08:51 AM
