Want more power from b16
I have a b16a in my 93 sol with a turbonetics 50 trim turbo, fmic , 3in exhaust, rc 550cc injectors, stock block. My question is what can i do to increase my horsepower? what can i add? or change to make more power? Anything will be appreciated. Thanks!
Moderator
Re: Want more power from b16
A new tune plus increased boost pressure is the way you do this. Boost control and tuning. You're in monroe MI, time to take it down to Pure Tuning to get it redone, and get advice about increasing boost pressure within safe limits.
http://www.pure-tuning.com
Habe you had the car on a dyno, if so what kind of nunbers did you put down and what are you using to tune?
I have almost the exact same setup in my del sol
B16a. Turbonetics 50trim. Bwr 3" vband down pipe with 3" dumped under car. Rc440 injectors and arp headstuds running 8psi and i put down 315whp@212tq. Well those numbers were from when i had a crushed downpipe that was mayne 2.5" and my exhaust was all effd up.
I am on s300 with a conservative tune as i have read not to go past 325-340ish on stock internals so we tuned it for just shy of that.
My car was tuned by King Motorsports out of new berlin, wi
http://www.kingmotorsports.com/c-173-dyno-tuning.aspx
I will also snap a pic of my dyno print out if you would like and post that as well.
I wish my laptop was working id sent you some data logging shots but its in shop right now.
What kind of turbo manifold are you running? Do you have arp headstuds or anything.
What are the specs on your turbo?
The Grumpiest
I'm going to guess that you bought it already boosted and have no idea what you have nor how it works. Hence the reason why such a simple question seems to be beyond you right now. Get it retuned. It's that simple.
Man U FTW
Its on 8psi...get a GM 3bar map sensor and retune. If you want the most from your stock block, look into tuning on e85. I wouldnt start tearing this setup apart in lieu of new parts before you actually use this setup to its fullest.
wtsapexipowerfc
06-09-2010 08:16 AM
