Car surges when hooked to mpx4250ap sensor?!
Old Jan 22, 2013 | 08:15 PM
whywhine's Avatar
Default Car surges when hooked to mpx4250ap sensor?!
I have a turbo B18 swapped hatch, car idles high and surges after start up but if I pull the vacuum on the mpx4250ap sensor it quits and idles fine, maybe it's hooked to the wrong vacuum port? Not sure.The car has did fine up to this point and now all of a sudden it's acting up, any help would be greatly appreciated!
Old Jan 22, 2013 | 08:27 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: Car surges when hooked to mpx4250ap sensor?!
what are you feeding the signal from that MAP sensor to? i have never heard of any use of it outside of Megasquirt application.
Old Jan 22, 2013 | 09:50 PM
whywhine's Avatar
I bought the car this way but they seem to have it tied in to the factory harness but with it unhooked and drive the car it will go lean.
Old Jan 22, 2013 | 10:21 PM
get a replacement stock MAP sensor.
Old Jan 23, 2013 | 02:45 AM
whywhine's Avatar
Is a stock MAP sensor going to work with the boost? Or the way they have it tuned?
Old Jan 23, 2013 | 06:17 AM
4genaccordfreak's Avatar
Get a proper Hondata or OMNI 4bar MAP and call it a day. They are factory replacement, bolt right in place of the stock one (depending on application) and use the factory harness connector.
Old Jan 23, 2013 | 07:00 AM
mpgmike's Avatar
It has been my understanding that Honda uses a 1.5 BAR MAP factory. Using a 2 Bar or even 4 BAR would skew the resolution to the point that the ECU cannot make heads or tails of the signal. One of the tricks used in other hobby arenas is to use the aftermarket MAP for your aftermarket electronics, use a factory MAP for the ECU, and put a 4.7 volt zener diode across the signal to limit what the ECU sees. Since Honda uses a 1.5 BAR MAP, it might need a 3.3 volt version (Digi-Key PN 568-5812-2-ND).
Hope this helps,
Mike
Old Jan 23, 2013 | 10:56 AM
whywhine's Avatar
Ok thanks guys. I just thought it was weird the car has been fine up to this point then all of a sudden it starts acting up.
Old Jan 23, 2013 | 03:53 PM
i think you have a can of worms with this car, and it is being opened.
do you know what sort of engine management does the car use?
Old Jan 24, 2013 | 03:47 AM
whywhine's Avatar
No clue on engine management.
11psiGSR
Jul 5, 2023 09:36 PM
GT500FTW
Apr 11, 2014 10:15 AM
quickchris
Jul 28, 2006 09:47 AM
beak
Jul 9, 2006 01:28 PM
