Authentic Garrett turbo?
Old Jan 15, 2013 | 01:39 PM
Mobeious's Avatar
Default Authentic Garrett turbo?
Does this look real or fake? already had him measure the compressor wheel and it measures out at a 50trim
water and oil cooled with a .63 hotside... but no garrett badges or anything
said he purchased it with a twin turbo kit and ended up selling everything and not doing it
Old Jan 15, 2013 | 01:59 PM
Westrock2000's Avatar
Default Re: Authentic Garrett turbo?
The only thing that stuck out was the font of the number 5 on the "A/R 0.50".
Compare to this housing.
http://www.skylinesaustralia.com/for...1144568146.jpg
It was the only one I saw that said 0.50, most were 0.60 or 0.70 that I found quickly looking. But they had normal looking fonts.
Old Jan 15, 2013 | 02:02 PM
TheShodan's Avatar
Moderator
Looks like a genuine Garrett, especially based upon the backplate. . See if there is an "A" on the cartridge that is stamped in.
using some older equipment, but "trim" doesn't say much. What's the inducer/exducer measurements?
Old Jan 15, 2013 | 02:06 PM
Mobeious's Avatar
Old Jan 15, 2013 | 02:07 PM
Mobeious's Avatar
67.5 and 48.25
Old Jan 15, 2013 | 02:16 PM
turbohatch96y7's Avatar
The G on the compressor housing looks kinda fishy to me.
Old Jan 15, 2013 | 04:10 PM
Mobeious's Avatar
anyone else
Old Jan 15, 2013 | 04:36 PM
TheShodan's Avatar
Moderator
Looks good to me. Also looks like an older V1 trim compressor wheel with an older stage II wheel. good to over 380whp. It will use 3/8NPT water fittings.
Old Jan 15, 2013 | 05:08 PM
Mobeious's Avatar
The guy said it was a ball bearing unit since it was water cooled but he didnt know ... so i guess we will find out
Old Jan 15, 2013 | 06:10 PM
TheShodan's Avatar
Moderator
Your guy is wrong. there are PLENTY of units that are watercooled that are not ball-bearing.
Watercooling is necessity for ball-bearing cartridges, not a sufficiency.
Old Jan 15, 2013 | 06:12 PM
Mobeious's Avatar
exactly what i told him .. plenty of water cooled journal bearings out there ... i told him to blow through the housing and see what happens lol
Old Jan 15, 2013 | 08:22 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
That also isn't a good indicator... On *most* ball bearing turbos, if you have the magic touch, you can feel the difference between a journal bearing and ball bearing if you slowly and delicately rotate the wheels. Only way to be 100% for sure is to take it apart... in this instance you do not have to though.
"The Shodan" has spoken, and you have bowed down in awe.
Old Jan 16, 2013 | 06:59 PM
TheShodan's Avatar
Moderator
And what would "blowing through the housing" accomplish? You don't want to use compressed air on a dry turbocharger like that.
Scotty Dosent Know
Jul 4, 2009 04:57 AM
4drteg54321
Apr 4, 2009 12:14 PM
sp00led
Feb 21, 2008 07:30 AM
VAsol
Jun 15, 2006 07:31 PM
RyanAutry
Jan 5, 2003 10:43 AM
