LS/Vtec Turbo Build
Old Feb 3, 2013 | 10:40 AM
xXBoosted_ITRXx's Avatar
Default LS/Vtec Turbo Build
So to make a long story short i spun a bearing in my stock 98 ITR and decided to rebuild for a turbo set-up. Thought id put up a post of my build to see what you guys think and whether or not my goals will be attainable. Looking for 350whp anything more will be great. It will be mainly a street car an occasionally tracked. So here is some info on my build let me know what you think....
98 ITR Head:
Skunk 2 Valves
Skunk 2 Springs and Retainers
ITR cams and gears
Victor X Intake Manifold
LS Block:
81.5mm Bore
Endyne Forged Pistons- 9.5:1.0
Eagle H-Beam Rods
ACL Bearings
Stock LS crank
ARP Head Studs
Turbo Kit:
t3/t4 57 trim turbonetics turbo
log manifold
front mount intercooler
HKS ssqv BOV
38mm Wastegate
3" exhaust
750cc injectors
skunk 2 fuel rail
255 Walbro Fuel Pump
I have Neptune for engine management but im thinking of going with Hondata s300. Anyone have any suggestions for which one i should go with. Also considering of upgrading the manifold to a sheepey built mini-ram with a 44mm wastegate.
Thanks for looking
Old Feb 3, 2013 | 11:10 AM
92egdxhatch's Avatar
Default Re: LS/Vtec Turbo Build
Should be able to make 350 no problem.
I have stock LS that made 348whp with a Garrett "57 trim"
Old Feb 3, 2013 | 11:35 AM
effin's Avatar
I can cosign. My relatively stock ls vtec on e85 made 350 no sweat. Im sure it will be a breeze for you
Old Feb 3, 2013 | 05:12 PM
hon2984's Avatar
you are gonna need a map sensor
Old Feb 4, 2013 | 11:20 AM
Darmok's Avatar
I agree 350 shouldn't be a problem at all with that setup
Old Feb 4, 2013 | 04:20 PM
Thanks for the comments guys.....so by the sounds of it 375 might be attainable lol
Old Feb 4, 2013 | 04:21 PM
Map sensor is on the list!
Old Feb 4, 2013 | 04:52 PM
wantboost's Avatar
Who is Mr Robot?
375 would be the upper limit of the turbo.
Old Feb 4, 2013 | 05:06 PM
Turbo-LS's Avatar
Making just under 400whp right now on bone stock gsr motor with a 57 trim. This is with E85 on 16 pounds of boost
350 is very attainable on that turbo
Old Feb 4, 2013 | 05:21 PM
Thanks for the comments guys. Anyone have a preference of Neptune or Hondata. I would like Hondata but already have the Neptune and wondering if it would be worth it spending the extra money for s300?
Old Feb 8, 2013 | 03:22 PM
2fast4uhonda's Avatar
I like Hondata personally
Old Feb 8, 2013 | 04:08 PM
TheShodan's Avatar
Moderator
If you got it already, use it. No advantage really at this stage in your build (or for most future stages either).
Old Feb 9, 2013 | 02:21 AM
wantboost's Avatar
Who is Mr Robot?
Neptune... if I were insistent on using a stock ecu tuning solution.
I prefer something like an AEM ems at minimum... much more user friendly and does more.. but it all depends on what sort of engine management solutions your particular build requires.
Old Feb 9, 2013 | 03:32 PM
BwoodEj1's Avatar
Cold starts suck on an aem ecu tho
Old Feb 9, 2013 | 04:47 PM
wantboost's Avatar
Who is Mr Robot?
I've never seen an AEM equipped car with a proper idle air valve have issues with cold starts
You also have to adjust cold start enrichment, temperature compensation, etc.
Can't just toss a map in the ecu and crank it in the middle of winter.. won't work
Most chipped Honda ECU softwares let the stock programming control cold starts, the software just scales those tables for changes in injector sizing.
Alex Groh
Sep 21, 2015 08:18 AM
808hawaii808
Feb 3, 2014 03:06 PM
bb6guy
Mar 1, 2010 01:25 PM
B18Sleeper
Sep 24, 2005 11:02 AM
romeirome1
Jan 13, 2004 07:30 PM
