Block guard or no guard?
Old Feb 13, 2013 | 05:09 AM
forryk's Avatar
Default Block guard or no guard and ARP rod bolts?
Hey guys!
1 question:
Just getting started on my high comp boost b16 engine. Gona use p73 pistons at about 10-12psi in the engine.
What do you think about using a block guard?
2 question:
Should i go with ARP rod bolts or just stick with OEM bolts? Max rev is gona be 8500 and 10-12psi boost.
Br, Jesper
Last edited by forryk; Feb 13, 2013 at 12:54 PM. Reason: Block guard or no guard and ARP rod bolts?
Old Feb 13, 2013 | 05:27 AM
kyden's Avatar
Default Re: Block guard or no guard?
i can't think of 1 good reason to use a block guard.
Old Feb 13, 2013 | 05:37 AM
JuggerNaut-CTR's Avatar
Yep...also cant think of 1 good reason to use a block guard
Old Feb 13, 2013 | 05:58 AM
Turbo-LS's Avatar
Sleeves will crack with or without a block guard if not tuned properly. Save your money. Also 10-12 psi means nothing if we dont know turbo size. HP goal is what you need to be looking at not target boost pressure. 10.5:1 just be sure you've got a decent tuner and good fuel.
Old Feb 13, 2013 | 06:47 AM
forryk's Avatar
Gona run a turbonetics 50trim 0.63 A/R, looking at about 350hp in the engine. The tuning wont be a problem, gona run it on E85.
Old Feb 13, 2013 | 11:50 AM
wantboost's Avatar
Who is Mr Robot?
350 on stock cast internals....
el oh el... that is all
Old Feb 13, 2013 | 11:57 AM
SiRCiviC94's Avatar
^ I wish
Old Feb 13, 2013 | 12:01 PM
Turbo-LS's Avatar
Stock cast internals will handle 350 no problem. With the right fuel and tune they will take 400ish without problems
Old Feb 13, 2013 | 12:11 PM
forryk's Avatar
Yeah. But the question still stands, will the oem rod bolts work or should i put in some ARP's? Did some research and some say it's worth it and some say it's not needed couse the Rod / Stroke Ratio is "perfect".
Old Feb 13, 2013 | 01:13 PM
mar778c's Avatar
Community Builder
Community Influencer
Instead of a block guard, how about forged pistons and rods.
Old Feb 13, 2013 | 01:56 PM
SiRCiviC94's Avatar
D16 Stock rod bolt? They blow on 93bhp ffs
Old Feb 13, 2013 | 03:40 PM
Turbo-LS's Avatar
Stock rod bolts are just fine for your Hp goal. We're pushing a completely stock GSR motor to a little over 400whp right now running mid 11's in a civic si coupe. Only issue we had was lifting the head which is about right as you should do headstuds after 350whp. Its not like your dealing with an LS bottom end . If was stock ls bottom end then i would recomend the rod bolts but i would also recomend not wasting the money and getting eagle rods and at least some nippon turbo pistons
wtsapexipowerfc
May 7, 2011 11:25 PM
crxrider07
27
Sep 7, 2008 07:45 AM
killacam661
Nov 26, 2007 12:35 PM
f22abuilder
Feb 23, 2006 11:32 AM
B18CHatch
Oct 18, 2001 03:06 PM
