Need help with Apexi Neo install. 97 civic running P28
OK guys, I have a 97 civic, 97 GSR B18C1 swap. Turboed. Im running a chipped P28 with a OBD2 > OBDI harness. Its just basemapped for my setup not tuned specifically and im lean so i need to add fuel. Dont need to be told its dangerous or to "GO GET IT TUNED." Please just help with the below inquiry.
My question in where can I find a correct wiring diagram for wiring in my Apexi Neo. I just am not sure do i just use the OBDI P28 diagram or what exctly (I have this diagram).
Couldnt I wire the Apexi between my swap harness so i dont damage the car harness OR the Ecu wires.
Re: Need help with Apexi Neo install. 97 civic running P28
thanks for the help. Im gonna install it this week ( i hope) and try to get my afr where it belongs at l;east enough to make it safer under boost. Its arratic at best but generally is 12.0-13.5 under boost. But then randomly will go 11.7 under boost. Sometimes its right sometimes its lean as fuuuuck. Id rather it go 10.0 than 13.5 lol
hamawizard
02-10-2010 07:10 PM
